Browse featured technical reports (E-Series)
Check out the links below to access technical reports related to E-Series hardware and SANtricity software. The links take you to a different documentation site.
Feature TRs
TR-4747: SANtricity Snapshot Feature Overview and Deployment Guide  |
Describes the solution architecture and how to use the E-Series storage system to import data from an existing remote storage device.  |
Describes the SANtricity Synchronous and Asynchronous Mirroring feature.  |
Describes the SANtricity Snapshot feature including GUI navigation instructions using SANtricity System Manager.  |
Describes how storage administrators can group sets of like disks into a pool topology where all the drives in the pool participate in the I/O workflow.  |
Describes an overview of the behavior of the ALB feature, its key configuration parameters, and its host interoperability enhancements.  |
Describes an overview of SANtricity Web Services, an API used for configuring and managing E-Series storage systems.  |
