Battery replacement requirements for E2800 storage systems
Before you replace an E2800 battery, review the requirements and considerations.
Each controller canister includes a battery that preserves cached data if the AC power fails.
Recovery Guru alerts
If the Recovery Guru in SANtricity System Manager reports one of following statuses, you must replace the affected battery:
Battery Failed
Battery Replacement Required
From SANtricity System Manager, review the details in the Recovery Guru to confirm that there is an issue with a battery and to ensure no other items must be addressed first.
Procedure overview
To protect your data, you must replace a failed battery as soon as possible.
The following is an overview of the steps required to replace a battery in an E2800 controller:
Prepare for replacement, following the appropriate steps for a duplex or simplex configuration.
Remove the controller canister.
Remove the failed battery.
Install the new battery.
Re-install the controller canister.
Complete the replacement, following the appropriate steps for a duplex or simplex configuration.
Duplex or simplex configuration
The steps to replace a battery depend on whether you have one or two controllers, as follows:
| If your storage array has… | You must… |
Two controllers (duplex) |
One controller (simplex) |
Requirements for replacing a battery
If you plan to replace a failed battery, you must have:
A replacement battery.
An ESD wristband, or you have taken other antistatic precautions.
Labels to identify each cable that is connected to the controller canister.
A management station with a browser that can access SANtricity System Manager for the controller. (To open the System Manager interface, point the browser to the controller's domain name or IP address.)
