E-Series storage systems
Prepare to replace an E2800 battery
Contributors netapp-driley netapp-jolieg NetAppZacharyWambold netapp-jsnyder
The steps to prepare for battery replacement depend on whether you have a duplex configuration (two controllers) or a simplex configuration (one controller).
Before you begin
Place controller offline (duplex)
If you have a duplex configuration, you must place the affected controller offline so you can safely remove the failed battery. The controller that you are not placing offline must be online (in the optimal state).
Note Perform this task only if your storage array has two controllers (duplex configuration).
Steps
  1. From SANtricity System Manager, review the details in the Recovery Guru to confirm that there is an issue with a battery and to ensure no other items must be addressed first.
  2. From the Details area of the Recovery Guru, determine which battery to replace.
  3. Back up the storage array's configuration database using SANtricity System Manager.
    If a problem occurs when you remove a controller, you can use the saved file to restore your configuration. The system will save the current state of the RAID configuration database, which includes all data for volume groups and disk pools on the controller.
    • From System Manager:
      1. Select Support › Support Center › Diagnostics.
      2. Select Collect Configuration Data.
      3. Click Collect.
        The file is saved in the Downloads folder for your browser with the name, configurationData-<arrayName>-<dateTime>.7z.
    • Alternatively, you can back up the configuration database by using the following CLI command:
      save storageArray dbmDatabase sourceLocation=onboard contentType=all file="filename";
  4. Collect support data for your storage array using SANtricity System Manager.
    If a problem occurs when you remove a controller, you can use the saved file to troubleshoot the issue. The system will save inventory, status, and performance data about your storage array in a single file.
    2. Select Collect Support Data.
    3. Click Collect.
      The file is saved in the Downloads folder for your browser with the name, support-data.7z.
  5. If the controller is not already offline, take it offline now using SANtricity System Manager.
    • From SANtricity System Manager:
      1. Select Hardware.
      2. Select the controller that you want to place offline.
      3. From the context menu, select Place offline, and confirm that you want to perform the operation.
        Note If you are accessing SANtricity System Manager using the controller you are attempting to take offline, a SANtricity System Manager Unavailable message is displayed. Select Connect to an alternate network connection to automatically access SANtricity System Manager using the other controller.
    • Alternatively, you can take the controllers offline by using the following CLI commands:
      For controller A: set controller [a] availability=offline
      For controller B: set controller [b] availability=offline
  6. Wait for SANtricity System Manager to update the controller's status to offline.
  7. Go to Remove E2800 controller canister.
    Caution Do not begin any other operations until after the status has been updated.
Power down the controller shelf (simplex)
If you have a simplex configuration, power down the controller shelf so you can safely remove the failed battery.
Note Perform this task only if your storage array has one controller (simplex configuration).
Steps
  1. Back up the storage array's configuration database using SANtricity System Manager.
      3. Click Collect.
  2. Collect support data for your storage array using SANtricity System Manager.
    3. Click Collect.
  3. Ensure that no I/O operations are occurring between the storage array and all connected hosts. For example, you can perform these steps:
    1. Stop all processes that involve the LUNs mapped from the storage to the hosts.
    2. Ensure that no applications are writing data to any LUNs mapped from the storage to the hosts.
    3. Unmount all file systems associated with volumes on the array.
      Note The exact steps to stop host I/O operations depend on the host operating system and the configuration, which are beyond the scope of these instructions. If you are not sure how to stop host I/O operations in your environment, consider shutting down the host.
      Caution Possible data loss — If you continue this procedure while I/O operations are occurring, you might lose data.
  4. Wait for any data in cache memory to be written to the drives.
    The green Cache Active LED on the back of the controller is on when cached data needs to be written to the drives. You must wait for this LED to turn off.
  5. From the home page of SANtricity System Manager, select View Operations in Progress.
  6. Confirm that all operations have completed before continuing with the next step.
  7. Turn off both power switches on the controller shelf.
  8. Wait for all LEDs on the controller shelf to turn off.
  9. Go to Remove E2800 controller canister.
