Other requirements
Additional requirements for FlexPod Datacenter include the following:
If you plan to use VMware ESXi as the hypervisor, refer to the Broadcom Compatibility Guide to verify that your hardware and software components are supported.
For an OpenShift-based deployment, ensure that you have the necessary hardware and software components that are compatible with OpenShift. Refer to the OpenShift Catalog for more information.
