FlexPod
Minimum Software Requirements
Contributors LuiMK1
This section describes the minimum software requirements for the different versions of FlexPod Express.
Software requirements for FlexPod Express with NetApp AFF or FAS
The software requirements for the FlexPod Express with NetApp FAS include:
  • ONTAP 9.1 or later
  • Cisco NX-OS version 7.0(3)I6(1) or later
  • In the Cisco UCS- managed configuration, Cisco UCS Manager UCS 4.0(1b)
All software must be listed and supported in the NetApp IMT. Certain software features might require more recent versions of code than the minimums listed in previous architectures.
Software requirements for FlexPod Express with E-Series
The software requirements for the FlexPod Express with E-Series include:
  • E-Series SANtricity software 11.30 or higher
  • Cisco UCS Manager 4.0(1b).
