Use cases
These are a few use case examples for monitoring and orchestration of NetApp storage from Cisco Intersight.
Use case 1: Monitoring NetApp storage inventory and widgets
When the NetApp storage environment is available in Cisco Intersight, you can monitor NetApp storage objects in detail from storage inventory and get an overview from storage widgets.
Deploy Intersight Assist OVA (OnPrem task in vCenter Environment).
Add NetApp AIQ UM devices in Intersight Assist.
Go to Storage and navigate through NetApp storage inventory.
Add Widgets for NetApp storage to your Monitor Dashboard.
Here is a link to the video showing NetApp ONTAP Storage Monitoring Features from Cisco Intersight.
Use case 2: NetApp storage orchestration using reference workflows
When NetApp storage and vCenter environments are available in Cisco Intersight, you can use end-to-end reference workflows available in GitHub through the FlexPod Intersight Workflow repository.
The reference workflows include storage and virtualization tasks. The README file for the repository provides the prerequisites needed for executing workflows, links to helpful resources (including documentation on how to import a workflow), and documentation links for each reference workflow.
Each workflow has a folder in the repository containing two files:
The JSON file to download and import into Intersight,
A documentation file that provides a view of the tasks in the workflow, workflow inputs, and an example execution of the workflow.
Perform the following to import and use a reference workflow:
Add the vCenter target to Intersight via Intersight Assist.
Download the JSON file for a reference workflow from the FlexPod-Intersight-Workflow repository.
Import the workflow into Intersight, then execute the workflow.
Here is a list of workflows available in the GitHub FlexPod-Intersight-Workflow repository:
Add Initiators to NetApp Initiator Group
New Export Policy for NetApp Volume
New NAS Datastore Using NetApp Smart Volume
New NetApp FC Data Interface
New NetApp Initiator Group
New NetApp iSCSI Data Interface
New NetApp NAS Data Interface
New NetApp Storage Virtual Machine
New VMFS Datastore Using NetApp Smart LUN
Remove Initiators from NetApp Initiator Group
Remove NAS Datastore Using NetApp Smart Volume
Remove NetApp Export Policy
Remove NetApp Initiator Group
Remove VMFS Datastore Using NetApp Smart LUN
Update NAS Datastore Using NetApp Smart Volume
Update VMFS Datastore Using NetApp Smart LUN
Use case 3: Custom workflows using designer-free form
When the NetApp Storage and vCenter environments are available in Cisco Intersight, you can build custom workflows using the NetApp storage and virtualization tasks.
Add vCenter target to Intersight via Intersight Assist.
Navigate to the Orchestration tab in Intersight.
Select Create Workflow.
Add storage and virtualization tasks to your workflows.
Here are the NetApp storage tasks that are available from Cisco Intersight:
Add ACL to NetApp CIFS Share
Add Client Match to NetApp Export Policy Rule
Add Export Policy to NetApp Volume
Add Rule to NetApp Export Policy
Add Schedule to NetApp Snapshot Policy
Confirm NetApp License Status
Confirm NetApp Storage Virtual Machine FCP Protocol Status
Edit NetApp Aggregates for Storage Virtual Machine
Edit NetApp Asynchronous SnapMirror Policy
Edit NetApp CIFS Share ACL Permission
Edit NetApp Export Policy Rule
Edit NetApp Snapshot Policy
Edit NetApp Snapshot Policy Schedule
Edit NetApp Volume Security Style
Edit NetApp Volume Snapshot Policy
Enable NetApp CIFS Services
Expand NetApp LUN
New NetApp Asynchronous SnapMirror Policy
New NetApp CIFS Server
New NetApp CIFS Share
Find NetApp Initiator Group LUN Map
Find NetApp LUN by ID
Find NetApp Volume by ID
New NetApp Export Policy
New NetApp Load-Sharing Mirrors for SVM Root Volume
New NetApp LUN
New NetApp LUN Map
New NetApp NAS Smart Volume
New NetApp Smart LUN
New NetApp SnapMirror Relationship for Volume
New NetApp Snapshot Policy
New NetApp Volume
New NetApp Volume Snapshot
Register DNS for NetApp Storage Virtual Machine
Remove ACL from NetApp CIFS Share
Remove Client Match from NetApp Export Policy Rule
Remove Export Policy from NetApp Volume
Remove Initiator from NetApp Initiator Group
Remove NetApp CIFS Server
Remove NetApp CIFS Share
Remove NetApp FC Data Interface
Remove NetApp IP Interface
Remove NetApp Load-Sharing Mirrors for SVM Root Volume
Remove NetApp LUN
Remove NetApp LUN Map
Remove NetApp NAS Smart Volume
Remove NetApp Smart LUN
Remove NetApp Snapmirror Relationship for Volume
Remove NetApp Snapmirror Policy
Remove NetApp Snapshot Policy
Remove NetApp Storage Virtual Machine
Remove NetApp Volume
Remove NetApp Volume Snapshot
Remove Rule from NetApp Export Policy
Remove Schedule from NetApp Snapshot Policy
Rename NetApp Volume Snapshot
Update NetApp Load-Sharing Mirrors for SVM Root Volume
Update NetApp Volume Capacity
To learn more about customizing workflows with NetApp storage and virtualization tasks, watch the video NetApp ONTAP Storage Orchestration in Cisco Intersight.
