FlexPod
Power and cabling requirements
Contributors kaminis85
This section describes the power and minimum cabling requirements for a FlexPod Express design.
Power requirements
The power requirements are based on U.S. specifications and assume the use of AC power. Other countries might have different power requirements. Direct current (DC) power options are also available for most components. For additional data about the maximum power required as well as other detailed power information, consult the detailed technical specifications for each hardware component.
For detailed Cisco UCS power data, see the Cisco UCS Power Calculator.
The following table lists the power ports required per device.
Cisco Nexus switches Power cables required
Cisco Nexus 3048
2x C13/C14 power cables for each Cisco Nexus 3000 series switch
Cisco Nexus 3524
Cisco Nexus 9396
2x C13/C14 power cables for each Cisco Nexus 9000 series switch
Cisco UCS chassis Power cables required
Cisco UCS 5108
2 CAB-US515P-C19-US/CAB-US520-C19-US for each Cisco UCS chassis
Cisco UCS B-Series servers Power cables required
Cisco UCS B200 M4
N/A; blade server is powered by chassis
Cisco UCS B420 M4
Cisco UCS B200 M5
Cisco UCS B480 M5
Cisco UCS C-Series servers Power ports required
Cisco UCS C220 M4
2 x C13/C14 power cables for each Cisco UCS server
Cisco UCS C240 M4
Cisco UCS C460 M4
Cisco UCS C220 M5
Cisco UCS C240 M5
Cisco UCS C480 M5
NetApp FAS controllers Power ports required (per HA pair)
FAS2554
2 x C13/C14
FAS2552
2 x C13/C14
FAS2520
2 x C13/C14
FAS8020
2 x C13/C14
E-Series controllers Power ports required (per HA pair)
E2824
2 x C14/C20
NetApp FAS disk shelves Power ports required
DS212C
2 x C13/C14
DS224C
2 x C13/C14
DS460C
2 x C19/C20 or 2 x C14/C19
DS2246
2 x C13/C14
DS4246
4 x C13/C14
E-Series disk shelves Power ports required
DE460C
DE224C
2 x C14/C20
DE212C
2 x C14/C20
Minimum cable requirements
This section describes the minimum cable requirements for a FlexPod Express design. Most FlexPod implementations require additional cables, but the number varies based on the deployment size and scope.
The following table lists the minimum number of cables required for each device.
Cisco Nexus 3000 Series switches Cables required
Cisco Nexus 31108
At least two 10GbE fiber or Twinax cables per switch
Cisco Nexus 3172PQ
Cisco Nexus 3048
Cisco Nexus 3524
Cisco Nexus 9396
DS212C
DS2246
Number of SAS cables depends on specific configuration of disk shelves
DS460C
DS224C
DS4246
E2800
  • At least one Gigabit Ethernet (1GbE) cable for management per controller
  • At least two 10GbE cables per controller (for iSCSI) or two FC cables matching speed requirements
DE460C
2 x mini-SAS HD cables per disk shelf
DE224C
DE212C
