FlexPod
NetApp components
Contributors LuiMK1
NetApp storage controllers provide the storage foundation in the FlexPod Express architecture for both boot and application data storage. This section lists the different NetApp options in the FlexPod Express architecture.
NetApp storage controller options
NetApp FAS
Redundant AFF C190, AFF A220, or FAS2750 series controllers are required in the FlexPod Express architecture. The controllers run ONTAP software. When ordering the storage controllers, the preferred software version can be preloaded on the controllers. For ONTAP, the cluster can be deployed either with a pair of cluster interconnect switches or in a switchless cluster configuration.
The part numbers listed in the following table are for an empty controller. Different options and configurations are available based on the storage platform selected. Consult your sales representative for details about these additional components.
Storage controller FAS part number Technical specifications
FAS2750
Based on individual options chosen
https://www.netapp.com/us/products/storage-systems/hybrid-flash-array/fas2700.aspx
FAS2720
AFF C190
https://www.netapp.com/us/products/entry-level-aff.aspx
AFF A220
https://www.netapp.com/us/documentation/all-flash-fas.aspx
FAS2620
http://www.netapp.com/us/products/storage-systems/fas2600/fas2600-tech-specs.aspx
FAS2650
E-Series storage
An HA pair of NetApp E2800 series controllers is required in the FlexPod Express architecture. The controllers run the SANtricity OS.
Storage controller Part number Technical specifications
E2800
http://www.netapp.com/us/products/storage-systems/e2800/e2800-tech-specs.aspx
NetApp Ethernet expansion modules
NetApp FAS
The following table lists the NetApp FAS10GbE adapter options.
Component Part number Technical specifications
NetApp X1117A
X1117A-R6
https://library.netapp.com/ecm/ecm_download_file/ECMM1280307
Note
The FAS2500 and 2600 series storage systems have onboard 10GbE ports.
The NetApp X1117A adapter is for FAS8020 storage systems.
E-Series storage
The following table lists the E-Series 10GbE adapter options.
10GbE iSCSI/16Gb FC 4-port
X-56025-00-0E-C
10GbE iSCSI/16Gb FC 2-port
X-56024-00-0E-C
Note
The E2824 series storage systems have onboard 10GbE ports.
The 10GbE iSCSI/16Gb FC 4-port host interface card (HIC) can be used for additional port density.
The onboard ports and the HIC can function as iSCSI adapters or FC adapters depending on the feature activated in SANtricity OS.
For more information about supported adapter options, see the Adapter section of NetApp Hardware Universe.
NetApp disk shelves and disks
NetApp FAS
A minimum of one NetApp disk shelf is required for storage controllers. The NetApp shelf type selected determines which drive types are available within that shelf.
The FAS2700 and FAS2600 series of controllers are offered as a configuration that includes dual storage controllers plus disks housed within the same chassis. This configuration is offered with SATA or SAS drives; therefore, additional external disk shelves are not needed unless performance or capacity requirements dictate more spindles.
Note
All disk shelf part numbers are for the empty shelf with two AC PSUs. Consult your sales representative for additional part numbers.
Disk drive part numbers vary according to the size and form factor of the disk you intend to purchase. Consult your sales representative for additional part numbers.
The following table lists the NetApp disk shelf options, along with the drives supported for each shelf type, which can be found on NetApp Hardware Universe. Follow the Hardware Universe link, select the version of ONTAP you are using, then select the shelf type. Under the shelf image, click Supported Drives to see the drives supported for specific versions of ONTAP and the disk shelves.
Disk shelf Part number Technical specifications
DS212C
DS212C-0-12
Disk Shelves and Storage Media Technical Specifications
Supported Drives on NetApp Hardware Universe
DS224C
DS224C-0-24
DS460C
DS460C-0-60
Disk Shelves and Storage Media Technical Specifications Supported Drives on NetApp Hardware Universe
DS2246
X559A-R6
DS4246
X24M-R6
DS4486
DS4486-144TB-R5-C
E-Series storage
A minimum of one NetApp disk shelf is required for storage controllers that do not house any drives in their chassis. The NetApp shelf type selected determines which drive types are available within that shelf.
The E2800 series of controllers are offered as a configuration that includes dual storage controllers plus disks housed within a supported disk shelf. This configuration is offered with SSD or SAS drives.
Note Disk drive part numbers vary according to the size and form factor of the disk you intend to purchase. Consult your sales representative for additional part numbers.
The following table lists the NetApp disk shelf options and the drives supported for each shelf type, which can be found on NetApp Hardware Universe. Follow the Hardware Universe link, select the version of ONTAP you are using, then select the shelf type. Under the shelf image, click Supported Drives to see the drives supported for specific versions of ONTAP and the disk shelves.
DE460C
E-X5730A-DM-0E-C
Disk Shelves Technical Specifications Supported Drives on NetApp Hardware Universe
DE224C
E-X5721A-DM-0E-C
DE212C
E-X5723A-DM-0E-C
NetApp software licensing options
NetApp FAS
The following table lists the NetApp FAS software licensing options.
NetApp Software Licensing Part Number Technical Specifications
Base cluster license
Consult your NetApp sales team for more licensing information.
E-Series storage
The following table lists the E-Series software licensing options.
NetApp software licensing Part number Technical specifications
Standard features
Premium features
NetApp Support licensing options
SupportEdge Premium licenses are required, and the part numbers for those licenses vary based on the options selected in the FlexPod Express design.
NetApp FAS
The following table lists the NetApp support licensing options for NetApp FAS.
NetApp Support licensing Part number Technical specifications
SupportEdge Premium4 hours onsite; months: 36
CS-O2-4HR
https://www.netapp.com/pdf.html?item=/media/19784-ds-3873.pdf
E-Series storage
The following table lists the NetApp support licensing options for E-Series storage.
Hardware support Premium 4 hours onsite; months: 36
SVC-O2-4HR-E
Software support
SW-SSP-O2-4HR-E
Initial installation
SVC-INST-O2-4HR-E
