FlexPod
Technical specifications and references
Contributors LuiMK1 kaminis85 netapp-revathid dorianH
Technical specifications provide details about the hardware components in a FlexPod solution, such as chassis, servers, switches, and storage controllers.
Cisco UCS fabric interconnects
The technical specifications for Cisco UCS fabric interconnect include form factor, the total number of ports and expansion slots, and throughput capacity. Refer to the table below for Cisco UCS fabric interconnect datasheets.
Component Cisco UCS datasheet
Cisco UCS 6664
Cisco UCS 6600 Series Fabric Interconnects
Cisco UCS 6652
Cisco UCS 6536
Cisco UCS 6536 Fabric Interconnect
Cisco UCS 6454
Cisco UCS 6400 Series Fabric Interconnects
Cisco UCS 64108
Cisco UCS 9108 100G Fabric Interconnect
Cisco UCS 9108 100G Fabric Interconnect for Cisco UCS X-Series Direct
Cisco UCS X-Series chassis
The technical specifications for Cisco UCS X-Series chassis, as shown in the table below, include the following components:
  • Number of rack units
  • Maximum number of nodes
  • Unified Fabric capability
  • Number of I/O bays for IFMs
Component Cisco UCS X9508 chassis
Rack units
7
8
Capable of Unified Fabric
Yes
I/O bays for IFMs
Two bays for Cisco UCS 9108 Intelligent Fabric Modules (IFMs)
For more information, see the Cisco UCS X9508 X-Series Chassis Datasheet.
Cisco UCS X-Series compute node
The technical specifications for Cisco UCS X-Series compute node include the following components:
  • Number of processor sockets
  • Processor support
  • Memory capacity
  • Size and speed
  • SAN boot support
  • Number of mezzanine adapter slots
  • I/O maximum throughput
  • Form factor
  • Maximum number of compute nodes per chassis
Refer to the table below for the technical specifications for Cisco UCS X-Series compute nodes.
Component
Cisco UCS datasheet
Cisco UCS X210c M7
Cisco UCS X210c M7 Compute Node
Cisco UCS X210c M8
Cisco UCS X210c M8 Compute Node
Cisco UCS X215c M8
Cisco UCS X215c M8 Compute Node
Cisco UCS X410c M7
Cisco UCS X410c M7 Compute Node
Cisco UCS X410c M8
Cisco UCS X410c M8 Compute Node
Cisco UCS C-Series rack servers
The technical specifications for the Cisco UCS C-Series rack servers include processor support, maximum memory capacity, the number of PCIe slots, and form factor. For additional details on compatible UCS server models, see the Cisco Hardware Compatibility list.
Refer to the table below for the technical specifications for Cisco UCS C-Series rack servers.
Cisco UCS C220 M7
Cisco UCS C220 M7 Rack Server
Cisco UCS C220 M8
Cisco UCS C220 M8 Rack Server
Cisco UCS C225 M6
Cisco UCS C225 M6 Rack Server
Cisco UCS C240 M7
Cisco UCS C240 M7 Rack Server
Cisco UCS C240 M8
Cisco UCS C240 M8 Rack Server
Cisco UCS C245 M6
Cisco UCS C245 M6 Rack Server
Cisco UCS C245 M8
Cisco UCS C245 M8 Rack Server
Refer to the table below for the technical specifications and GPU options for Cisco UCS C-Series rack servers optimized for AI use cases.
Cisco UCS C-Series rack server Technical specifications
Cisco UCS C845A M8
Cisco UCS C845A M8 Rack Server
Cisco UCS C880A M8
Cisco UCS C880A M8 Rack Server
Cisco UCS C885A M8
Cisco UCS C885A M8 Rack Server
Cisco UCS VIC adapters
The technical specifications for Cisco UCS Virtual Interface Card (VIC) adapters for Cisco Servers include the following components:
  • Number of uplink ports
  • Performance per port (IOPS)
  • Power
  • Number of blade ports
  • Hardware offload
  • Single root input/output virtualization (SR-IOV) support
All currently validated FlexPod architectures use a Cisco UCS VIC. Other adapters are supported if they are listed on the NetApp IMT and are compatible with your deployment of FlexPod, but they might not deliver all the features that are outlined in corresponding reference architectures. The following table illustrates the Cisco UCS VIC adapter datasheets.
Cisco UCS Virtual Interface Adapters
Cisco UCS VIC Datasheets
Cisco Nexus switches
The technical specifications for Cisco Nexus Switches are contained in the datasheet for each model. Specifications include the form factor size; the number of supervisors, fabric module, and line card slots; and the maximum number of ports. These datasheets can be found in the following table.
Component Cisco Nexus datasheet
Cisco Nexus 9200 Series
Cisco Nexus 9200 Series Switches
Cisco Nexus 9300 Series
Cisco Nexus 9300 Series Switches
Cisco Nexus 9400 Series
Cisco Nexus 9400 Series Switches
Cisco Nexus 9500 Series
Cisco Nexus 9500 Series Switches
Cisco Nexus 9800 Series
Cisco Nexus 9800 Series Switches
Cisco MDS options
The technical specifications for Cisco Nexus Switches are contained in the datasheet for each model which are listed in the following table.
Cisco MDS Switch Description
Cisco MDS 9100 Series Switches
Cisco MDS 9200 Series Switches
Cisco MDS 9300 Series Switches
Cisco MDS 9700 Series directors
Cisco MDS 9700 Series Switches
Cisco Application Policy Infrastructure controller
When you deploy Cisco ACI, you must configure three Cisco APICs. The following table lists the Cisco APIC datasheet.
Component Cisco Application Policy Infrastructure datasheet
Cisco Application Policy Infrastructure Controller
Cisco APIC Datasheet
SFP modules
For information about the SFP modules, review the following resources:
NetApp storage controllers
The technical specifications for NetApp storage controllers include the platform configuration, max raw capacity, memory, form factor, ONTAP version requirements, disk shelves, etc.
NetApp AFF A-Series
NetApp AFF A-Series storage controllers are supported for use in FlexPod Datacenter. Additional information can be found in the AFF A-series Technical Specifications datasheet and in the NetApp Hardware Universe. See the platform-specific documentation listed in the following table for detailed information about a specific AFF Model.
Component AFF A-Series controller platform documentation
NetApp AFF A20
AFF A20 Key Specifications
NetApp AFF A30
AFF A30 Key Specifications
NetApp AFF A50
AFF A50 Key Specifications
NetApp AFF A70
AFF A70 Key Specifications
NetApp AFF A90
AFF A90 Key Specifications
NetApp AFF A1K
AFF A1K Key Specifications
NetApp AFF C-Series
NetApp AFF C-Series storage controllers are supported for use in FlexPod Datacenter. Additional information can be found in the AFF C-Series Technical Specifications datasheet and in the NetApp Hardware Universe. See the platform- specific documentation listed in the following table for detailed information about a specific AFF Model.
Component AFF C-Series controller platform documentation
NetApp AFF C30
AFF C30 Key Specifications
NetApp AFF C60
AFF C60 Key Specifications
NetApp AFF C80
AFF C80 Key Specifications
NetApp ASA
NetApp ASA storage controllers are supported for use in FlexPod Datacenter. Additional information can be found in the NetApp ASA Technical Specifications datasheet and in the NetApp Hardware Universe. See the platform- specific documentation listed in the following table for detailed information about a specific ASA Model.
Component NetApp ASA controller platform documentation
NetApp ASA A20
ASA A20 Key Specifications
NetApp ASA A30
ASA A30 Key Specifications
NetApp ASA C30
ASA C30 Key Specifications
NetApp ASA A50
ASA A50 Key Specifications
NetApp ASA A70
ASA A70 Key Specifications
NetApp ASA A90
ASA A90 Key Specifications
NetApp ASA A1K
ASA A1K Key Specifications
NetApp FAS Series
FAS storage controllers are supported for use in FlexPod Datacenter. Additional information can be found in NetApp FAS Technical Specifications and the NetApp Hardware Universe. See the platform-specific documentation listed in the following table for detailed information about a specific FAS model.
Component FAS Series controller platform documentation
NetApp FAS2750
FAS2750 Key Specifications
NetApp FAS2820
FAS2820 Key Specifications
NetApp FAS50
FAS50 Key Specifications
NetApp FAS70
FAS70 Key Specifications
NetApp FAS90
FAS90 Key Specifications
NetApp AFX
NetApp AFX storage controllers are supported for use in FlexPod Datacenter. Additional information can be found in the NetApp AFX Technical Specifications datasheet and in the NetApp Hardware Universe. See the platform-specific documentation listed in the following table for detailed information about a specific AFX Model.
Component
NetApp AFX controller platform documentation
NetApp AFX 1K
AFX Documentation
NetApp AFX 2K
NetApp disk shelves
The technical specifications for NetApp disk shelves include the form factor size, the number of drives per enclosure, and the shelf I/O modules; this documentation can be found in the following table. For more information, refer to the NetApp Hardware Universe.
Component NetApp FAS/AFF disk shelf documentation
NetApp DS212C Disk Shelf
NetApp Disk Shelf Documentation
NetApp DS224C Disk Shelf
NetApp DS460C Disk Shelf
NetApp NS224 Disk Shelf
NetApp NS224 w/NSM 100B Disk Shelf
NetApp NX224 Disk Shelf
NetApp drives
The technical specifications for NetApp drives include the form factor size, disk capacity, disk RPM, supporting controllers, and ONTAP version requirements. These specifications can be found in the Drives section of the NetApp Hardware Universe.
