FlexPod
NetApp components
Contributors LuiMK1 kaminis85 dorianH netapp-revathid
NetApp storage controllers provide the storage foundation in the FlexPod architecture for both boot and application data storage. NetApp components include storage controllers, cluster interconnect switches, drives and disk shelves, and licensing options.
NetApp storage controller options
Redundant NetApp FAS, AFF, ASA, or AFX controllers are required in the FlexPod architecture. The controllers run ONTAP software. When the storage controllers are ordered, the preferred software version can be preloaded on the controllers. For ONTAP, a complete cluster is ordered. A complete cluster includes a pair of storage controllers and a cluster interconnect (switch or switchless).
Note A switchless cluster configuration is supported only for a two-node configuration. Cluster interconnect switches are required for configurations with four or more nodes, and are optional for a two-node configuration.
Different options and configurations are available, depending on the selected storage platform. Consult your sales representative for details about these additional components.
The controller families that are listed in the table below are appropriate for use in a FlexPod Datacenter solution because their connection to the Cisco Nexus switches is seamless. See the NetApp Hardware Universe for specific compatibility details on each controller model.
NetApp storage Family for FlexPod Datacenter Model Technical specifications
AFF A-Series
AFF A20
AFF A-Series Datasheet
AFF A30
AFF A50
AFF A70
AFF A90
AFF A1K
AFF C-Series
AFF C30
AFF C-Series Datasheet
AFF C60
AFF C80
ASA
ASA A20
ASA Datasheet
ASA A30
ASA C30
ASA A50
ASA A70
ASA A90
ASA A1K
FAS
FAS2750
FAS Datasheet
FAS2820
FAS50
FAS70
FAS90
AFX
AFX 1K
AFX Datasheet
AFX 2K
Cluster interconnect switch options
The following table lists the Nexus cluster interconnect switches that are available for FlexPod architectures. FlexPod supports all ONTAP-supported cluster switches, including non-Cisco switches, provided they are compatible with the version of ONTAP being deployed.
For a list of supported cluster interconnect switches, go to NetApp Hardware Universe, click on Products > Networking > Switches, and then select Cluster InterConnect Switch. You can filter by vendor type, select a switch, and click on Show results to see detailed information about the switch.
The table below lists the Cisco switches that can be used as a cluster interconnect switch.
Cluster interconnect switch Technical specifications
Cisco Nexus 9336C-FX2
NetApp Documentation: Cisco Nexus 9336C-FX2 switches
NetApp disk shelf and drive options
A minimum of one NetApp disk shelf is required for the storage controllers that do not have a built-in disk shelf. The selected NetApp shelf type determines which drive types are available within that shelf.
Note For all disk shelves and disk part numbers, consult your sales representative.
The following table lists the NetApp disk shelf options for FlexPod Datacenter along with links to their technical specifications.
To get the list of supported drives for your disk shelf, go to NetApp Hardware Universe, under Products > Storage > Shelves select ONTAP (AFF, ASA, FAS) or ONTAP (AFX), select the version of ONTAP you are using, then select the shelf type (example: DS212C) and click on Show Results. Click on Supported Drives to see the drives supported for specific versions of ONTAP and the disk shelves.
Disk shelf Technical specifications
DS212C
Disk Shelves and Storage Media
DS224C
DS460C
NS224
NS224 w/NSM100B
NX224
NetApp software licensing options
The following table lists the NetApp software licensing options.
NetApp Software Licensing Technical Specifications
ONTAP One for AFF, FAS, and AFX
Consult your NetApp sales team for more licensing information.
ONTAP One for SAN for ASA
Refer to the following link for more information about NetApp software licensing: NetApp Software Licensing.
NetApp Support licensing options
SupportEdge Premium licenses are required, and the part numbers for those licenses vary based on the options selected in the FlexPod Datacenter design.
The following table lists the NetApp support licensing options for NetApp AFF, ASA, FAS, and AFX Storage systems.
NetApp Support licensing Technical specifications
NetApp SupportEdge
https://www.netapp.com/netapp-services/
