Terraform execution from controller
We can execute the Terraform plan using a controller. You can skip this section if you have already executed your Terraform plan using an ICO workflow.
Prerequisites
Setup of the solution begins with a management workstation that has access to the Internet and with a working installation of Terraform.
A guide for installing Terraform can be found here.
Clone GitHub repo
The first step in the process is to clone the GitHub repo to a new empty folder on the management workstation. To clone the GitHub repository, complete the following steps:
From the management workstation, create a new folder for the project. Create a new folder inside this folder named
/root/snapmirror-cvoand Clone the GitHub repo into it. -
Open a command-line or console interface on the management workstation and change directories to the new folder just created.
Clone the GitHub collection using the following command:
Git clone https://github.com/NetApp-Automation/FlexPod-hybrid-cloud-for-GCP-with-Intersight-and-CVO
Change directories to the new folder named
snapmirror-cvo.
Terraform execution
Init. Initialize the (local) Terraform environment. Usually executed only once per session.
Plan. Compare the terraform state with the as-in state in the cloud and build and display an execution plan. This does not change the deployment (read-only).
Apply. Apply the plan from the plan phase. This potentially changes the deployment (read and write).
Destroy. All resources that are governed by this specific terraform environment.
For details, see here.
