FlexPod Datacenter for SAP Solution with Cisco UCS Manager 4.0 and NetApp AFF A–Series - Design
PDF of this doc site
Hybrid Cloud
Creating your file...
Your file is ready
Pramod Ramamurthy, Cisco
Marco Schoen, NetApp
This document describes the Cisco and NetApp FlexPod solution, which is a validated approach for deploying SAP HANA Tailored Data Center Integration (TDI) environments. This validated design provides guidelines and a framework for implementing SAP HANA with best practices from Cisco and NetApp.
FlexPod is a leading integrated infrastructure that supports a broad range of enterprise workloads and use cases. This solution allows you to quickly and reliably deploy SAP HANA with a model of a tailored data center integration mode.
