FlexPod
Connectivity requirements
Contributors LuiMK1
This section describes the general connectivity requirements for the different versions of FlexPod Express.
Connectivity requirements for FlexPod Express with NetApp AFF/ ASA/ FAS
The connectivity requirements for FlexPod Express with NetApp AFF/ ASA/ FAS generally include:
  • NetApp storage controllers must be directly connected to the Cisco Nexus switches.
  • For Cisco UCS X-Series Direct deployments, the NetApp storage controllers can be connected directly to the embedded Fabric Interconnects.
  • No additional equipment can be placed inline between the core FlexPod components.
  • Virtual port channels (vPCs) are required to connect the Cisco Nexus 9000 series switches to the NetApp storage controllers.
  • Although it is not required, enabling jumbo frame support is recommended throughout the environment.
Refer to the FlexPod Express topologies section for connectivity requirements specific to each topology.
