FlexPod
Cisco components
Contributors LuiMK1
Cisco is a substantial contributor to the FlexPod Express design and architecture; it contributes the compute and networking layers of the solution. This section describes the Cisco UCS and Cisco Nexus components that are available for FlexPod Express.
Cisco UCS B-Series blade server options
Cisco UCS B-Series blades currently supported in the Cisco UCS Mini platform are B200 M5 and B420 M4. Other blades will be listed in the following table as they become supported in the Cisco UCS Mini platform.
Cisco UCS B-Series server Part number Technical specifications
Cisco UCS B200 M5
UCSB-B200-M5
https://www.cisco.com/c/en/us/support/servers-unified-computing/ucs-b200-m5-blade-server/model.html
Cisco UCS B200 M4
UCSB-B200-M4
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf
Cisco UCS B420 M4
UCSB-B420-M4
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b420m4-spec-sheet.pdf
Cisco UCS C-Series rack server options
Cisco UCS C-Series blades are available in one-rack and two-rack unit (RU) varieties, with various CPU, memory, and I/O options. The part numbers listed in the following table are for the base server; they do not include CPUs, memory, disk drives, PCIe cards, or the Cisco FEX. Multiple configuration options are available and supported in FlexPod.
Cisco UCS C-Series rack server Part number Technical specifications
Cisco UCS C220 M4
UCSC-C220-M4S
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c220m4-sff-spec-sheet.pdf
Cisco UCS C240 M4
UCSC-C240-M4S
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c240m4-sff-spec-sheet.pdf
Cisco UCS C460 M4
UCSC-C460-M4
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c460m4_specsheet.pdf
Cisco Nexus switches
Redundant switches are required for all FlexPod Express architectures.
The FlexPod Express with NetApp AFF or FAS architecture is built with the Cisco Nexus 31108 switch. FlexPod Express with the Cisco UCS Mini (Cisco UCS- managed) architecture is validated by using the Cisco Nexus 3524 switch. This configuration can also be deployed with a standard switch.
The FlexPod Express with E-Series can be deployed with a standard switch.
The following table lists the part numbers for the Cisco Nexus series chassis; they do not include additional SFP or add-on modules.
Cisco Nexus Series switch Part number Technical specifications
Cisco Nexus 3048
N3K-C3048TP-1GE
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-685363.html
Cisco Nexus 31108
N3K-C31108PC-V
http://www.cisco.com/c/en/us/products/switches/nexus-31108pc-v-switch/index.html
Cisco Nexus 9396
N9K-C9396PX
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-729405.html
Cisco Nexus 3172
N3K-C3172
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-729483.html
Cisco Support licensing options
Valid SMARTnet support contracts are required on all Cisco equipment in the FlexPod Express architecture.
Note The licenses required and the part numbers for those licenses should be verified by your sales representative because they can differ for different products.
The following table lists the Cisco support licensing options.
Cisco Support licensing License guide
SMARTnet 24x7x4
http://www.cisco.com/web/services/portfolio/product-technical-support/smartnet/index.html
