Configuring a connection between Workflow Automation and Unified Manager
You can configure a secure connection between OnCommand Workflow Automation (WFA) and Unified Manager. Connecting to Workflow Automation enables you to use protection features such as SnapMirror and SnapVault configuration workflows, as well as commands for managing SnapMirror relationships.
Before you begin
The installed version of Workflow Automation must be 4.2 or greater.
You must have installed “WFA pack for managing Clustered Data ONTAP” version 9.5.0 or greater on the WFA server. You can download the required pack from the NetAppStorage Automation Store.
You must have the name of the database user that you created in Unified Manager to support WFA and Unified Manager connections.
This database user must have been assigned the Integration Schema user role.
You must be assigned either the Administrator role or the Architect role in Workflow Automation.
You must have the host address, port number 443, user name, and password for the Workflow Automation setup.
You must have the OnCommand Administrator or Storage Administrator role.
Steps
In the toolbar, click
, and then click Workflow Automation in the left Setup menu. -
In the OnCommand Unified Manager Database User area of the Setup/Workflow Automation page, select the name, and enter the password for the database user that you created to support Unified Manager and Workflow Automation connections.
In the OnCommand Workflow Automation Credentials area of the Setup/Workflow Automation page, enter the host name or IP address (IPv4 or IPv6), and the user name and password for the Workflow Automation setup.
You must use theUnified Manager server port (port 443).
Click Save.
If you use a self-signed certificate, click Yes to authorize the security certificate.
The Setup/Workflow Automation page displays.
Click Yes to reload the web UI, and add the Workflow Automation features.
