Identifying the best node for a busy LIF using the CLI
You can display information about all the ports in a cluster. You can view information such as the network port role (cluster, data, or node-management), link status, maximum transmission unit (MTU), speed setting and operational status, and the port's interface group, if applicable.
Steps
To display port information, enter the following command:
network port showThe following example displays information about network ports that have a data role and are up in the cluster:
cluster1::> network port show -role data -link up Auto-Negot Duplex Speed (Mbps) Node Port Role Link MTU Admin/Oper Admin/Oper Admin/Oper ---- ---- ----- ---- ---- ---------- ---------- ---------- node1 e0M data up 1500 true/true full/full auto/100 e0b data up 1500 true/true full/full auto/1000 node2 e0b data up 1500 true/true full/full auto/1000 -
Check for destination ports that are in the same network as the source home port and home node.
For example, the destination home port and home node should be on the same VLAN where applicable.
To identify the least busy port, choose a data port that has the least number of connections.
