Database Backup Settings dialog box
You can use the Database Backup Settings dialog box to specify a backup path and retention count and to enable a backup schedule for a selected backup instance.
You can change the following database backup settings:
Path
Specifies the path to the location where you store the backup files. The following table specifies the backup path format, and default locations, for different operating systems:
Host operating system Backup path format Virtual appliance
/opt/netapp/data/ocum-backupRed Hat Enterprise Linux or CentOS
/data/ocum-backupMicrosoft Windows
C:\ProgramData\NetApp\OnCommandAppData\ocum\backup\ -
Retention Count
Specifies the maximum number of backups to be retained by Unified Manager. The default value is ten.
Schedule Frequency Enable
This option enables you to specify when to schedule a backup; you can choose daily or weekly.
Daily
Specifies the daily backup schedule with the time.
Weekly
Specifies the weekly backup schedule with the day and time.
Command buttons
Save and Close
Saves the backup file and closes the dialog box. Unified Manager saves the backup file in the following format:
um_um_version_backup_os_timestamp.7z. -
Cancel
Closes the Database Backup Settings dialog box without saving your changes.
