Add Script dialog box
The Add Script dialog box enables you to add scripts to Unified Manager. You can configure alerts with your scripts to automatically resolve events that are generated for storage objects.
You must have the OnCommand Administrator or Storage Administrator role.
Select Script File
Enables you to select a script for the alert.
Enables you to specify a description for the script.
