The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Creating a project using BIRT
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
Your file is ready
Before creating a report for import into Unified Manager, you must first create a project using BIRT.
Before you begin
You must have downloaded and extracted the BIRT .zip file.
Steps
From the Eclipse interface, select File > New > Project.
Expand the Business Intelligence and Reporting Tools folder, select Report Project, and click Next.
Type the project name and click Finish.
