Management/Scripts page
The Management/Scripts page enables you to add your custom scripts to Unified Manager. You can associate these scripts with alerts to enable automatic reconfiguration of storage objects.
The Management/Scripts page enables you to add or delete scripts from Unified Manager.
Command buttons
Add
Displays the Add Script dialog box, which enables you to add scripts.
Delete
Deletes the selected script.
List view
The list view displays, in tabular format, the scripts that you added to Unified Manager.
Name
Displays the name of the script.
Displays the description of the script.
