Edit Rule dialog box
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
You can use the Edit Rule dialog box to edit the properties of a rule, such as the file types, directory paths, or owners. You can also select an appropriate storage class for the rule. For example, when a certain file path is no longer valid, you can delete the file path from the corresponding rule.
Rule Name
Displays the name of the rule.
Matching Criteria
Displays a list of conditions related to the selected rule template. The condition list changes based on the rule template selected.
Add
Enables you to add a new rule property, a new file type, a file path, or a new owner. For example, if you had specified the rule template, “Place all files with the specified owner names in a suitable storage class”, the Add button enables you to add the owner's name.
Delete
Enables you to delete a selected rule property.
Content Placement area
Displays the list of storage classes. You can select an appropriate storage class for the selected rule.
Command buttons
Update
Updates the changes made to the rule and closes the Edit Rule dialog box.
Cancel
Cancels the recent changes made to the rule and closes the Edit Rule dialog box.
