Volume Data Protection Configuration report
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Volume Data Protection Configuration report enables you to view the unprotected volumes and storage virtual machines (SVMs) that are used in a node or a cluster. This information enables you to understand the data protection risks for your system, and to view the details of the protected volumes and unprotected volumes in your system.
The Volume Data Protection Configuration report is displayed in two formats:
Protected and Unprotected Volumes pie chart
Unprotected Volume Data tabular view
Displays the relative percentage of the protected volumes and unprotected volumes in your system.
Cluster
Displays the cluster name.
Storage Virtual Machine
Displays the name of the storage virtual machine (SVM) that contains the volume.
Volume
Displays the volume name.
Total Data Capacity (GB)
Displays the total data capacity (used plus available) in GB.
Used Data Capacity (GB)
Displays the used data capacity (in GB).
Used Data %
Displays the used data capacity as a percentage.
Available Data Capacity (GB)
Displays the available data capacity (in GB).
Available Data %
Displays the available data capacity as a percentage.
Snapshot Reserve Used Capacity (GB)
Displays the amount of space that is used by Snapshot copies from Snapshot reserve (in GB).
Snapshot Reserve Used %
Displays the amount of space that is used by Snapshot copies from Snapshot reserve as a percentage.
Snapshot Reserve Available Capacity (GB)
Displays the amount of space that is available for Snapshot copies (in GB).
Snapshot Reserve Available %
Displays the amount of space that is available for Snapshot copies as a percentage.
Snapshot Reserve Total Capacity (GB)
Displays the total snapshot reserve capacity of the aggregate (in GB).
Days To Full
Displays the estimated number of days remaining before the aggregate reaches full capacity.
Space Full Threshold %
Displays the percentage at which an aggregate is full.
Space Nearly Full Threshold %
Displays the percentage at which an aggregate is nearly full.
Daily Growth Rate %
Displays the growth rate that occurs every 24 hours in the volume.
Total Number Of Inodes
Displays the total number of inodes in the volume.
Inode Utilization
Specifies the inode space that is used in the volume.
Quota Committed Capacity
Displays the space that is reserved in the volumes.
Quota Overcommitted Capacity (GB)
Displays the amount of space that can be used (in GB) before the system generates the Volume Quota Overcommitted event.
Snapshot Autodelete
Displays whether automatic deletion of Snapshot copies is enabled or disabled.
Deduplication
Displays whether deduplication is enabled or disabled for the volume.
Deduplication Space Savings (GB)
Displays the amount of space that is saved in a volume by using deduplication (in GB).
Compression
Displays whether compression is enabled or disabled for the volume.
Compression Space Savings (GB)
Displays the amount of space that is saved in a volume by using compression (in GB).
Thin Provisioned
Displays whether space guarantee is set for the selected volume. Valid values are Yes and No.
Autogrow
Displays whether the FlexVol volume automatically grows in size when it is out of space.
Space Guarantee
Displays the FlexVol volume setting control when a volume removes free blocks from an aggregate.
State
Displays the state of the volume that is being exported.
SnapLock Type
Indicates whether the volume is a SnapLock or non-SnapLock volume.
Expiry Date
