Save Custom Report dialog box
You can use the Save Custom Report dialog box to save a custom report after making additional changes to the custom report.
Properties
You can save a custom report by specifying properties such as the description.
Report Name
Displays the name of the custom report. This field cannot be edited.
Specifies the description of the customization made on the custom report. Description cannot exceed 150 characters .
Command buttons
The command buttons enable you to perform the following tasks:
Save
Saves the custom report .
Cancel
Cancels the recent changes and closes the Save Custom Report dialog box.
