Edit Rule dialog box (Advanced edit)
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
You can use the Edit Rule dialog box to edit the properties of a rule that is not created by using a template. The rule properties you can edit include the file types, directory paths, matching criteria, or owners. You can select an appropriate storage class for the rule. For example, you can edit the conditions specified in the matching criteria of a rule.
Rule Name
Displays the name of the rule.
Matching Criteria
Displays a list of conditions related to the selected rule template. The condition list changes based on the rule template selected. You can expand the rules and modify the rule properties, as required.
Content Placement area
Displays the list of storage classes. You can select an appropriate storage class for the selected rule.
Command buttons
Update
Updates the changes made to the rule and closes the Edit Rule dialog box.
Cancel
Cancels the recent changes made to the rule and closes the Edit Rule dialog box.
