Annotate SVM dialog box
The Annotate SVM dialog box enables you to manually annotate storage objects. You can select either a single SVM or multiple SVMs and annotate with a specific value pair from the existing list of annotations.
You must have the OnCommand Administrator or Storage Administrator role.
Annotation=Value Pairs
Enables you to select the required annotation for the selected SVM.
Apply
Applies the selected annotation to the SVM.
Cancel
Closes the Annotate SVM dialog box without saving your changes.
