Add Group Rule dialog box
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
The Add Group Rule dialog box enables you to create group rules in Unified Manager to dynamically group storage objects. You can later configure and apply group actions for the group.
You must have the OnCommand Administrator or Storage Administrator role.
Name
Specifies the name of the group rule.
Target Object Type
Specifies the type of storage objects to include in the group.
Group
Specifies the name of the group for which the group rule is created.
Conditions
Specifies conditions that determine which storage objects can be included in a group.
Condition group
Specifies condition groups which have one or more conditions defined for including storage objects in a group.
Command buttons
Save and Add
Adds the group rule and enables you to add another group rule without closing the dialog box.
Add
Adds the group rule and closes the Add Group Rule dialog box.
Cancel
Cancels the changes and closes the Add Group Rule dialog box.
Add Condition
Adds a condition to define the group rule.
Add Condition Group
Adds a condition group to define conditions for the group rule.
