How 7-Mode configuration files map to clustered Data ONTAP commands
In Data ONTAP operating in 7-Mode, you typically use flat files to configure the storage system. In clustered Data ONTAP, you use configuration commands. You need to know how 7-Mode configuration files map to clustered Data ONTAP configuration commands.
| 7-Mode configuration file | Clustered Data ONTAP configuration command |
Not applicable. The |
In clustered Data ONTAP, the retention of node configuration information processed at boot is transferred to other internal files that retain the configuration information. In Data ONTAP operating in 7-Mode, features configured in memory are also retained in the |
Intercluster relationships exist between two clusters. Intracluster relationships exist between two nodes on the same cluster. Authentication of the remote cluster occurs during the creation of the cluster peering relationship. Intracluster |
