Configuring zones by using the FC zone plan
After completing the transition, you must configure the zones by using the FC zone plan to group the initiator hosts and targets for providing data access from the cluster.
The cluster and initiator hosts must be connected to the switch.
The FC zone script file must be accessible.
Steps
Log in to the CLI of the switch.
Copy and execute the required zone commands one at a time.
The following example runs the zone commands on the switch:
switch1:admin>config terminal # Enable NPIV feature feature npiv zone name auto_transition_igroup_d31_194bf3 vsan 10 member pwwn 21:00:00:c0:dd:19:4b:f3 member pwwn 20:07:00:a0:98:32:99:07 member pwwn 20:09:00:a0:98:32:99:07 ....... ....... ....... copy running-config startup-config
The initiator hosts can access data from the cluster.
