How 7-Mode commands map to ONTAP commands
You can use the tables provided to find the ONTAP equivalents of 7-Mode commands, with the exception of the options command.
The following tables list the ONTAP equivalents of the 7-Mode options command. Information about understanding these tables is also provided.
A-E
A
7-Mode command ONTAP command
acpadmin configure
system node run -node {nodename|local} acpadmin configure
acpadmin list_all
system node run -node {nodename|local} acpadmin list_all
acpadmin stats
system node run -node {nodename|local} acpadmin stats
aggr add
aggr add
aggr add-disks
storage aggregate add-disks
aggr create
aggr create
storage aggregate create
aggr destroy
aggr delete
storage aggregate delete
aggr media_scrub
system node run -node {nodename|local} aggr media_scrub
aggr offline
aggr offline
storage aggregate offline
aggr online
aggr online
storage aggregate online
aggr options
aggr modify
storage aggregate {show | modify}
aggr rename
aggr rename
storage aggregate rename
aggr restrict
aggr restrict
storage aggregate restrict
aggr scrub
aggr scrub
storage aggregate scrub
aggr show_space
aggr show-space
storage aggregate show-space
aggr status
aggr show
aggr verify
system node run -node {nodename|local} aggr verify
autosupport destinations
system node autosupport destinations
autosupport history
autosupport history
system node autosupport history
autosupport manifest
system node autosupport manifest
autosupport trigger
autosupport trigger
system node autosupport trigger
B
backup status
system node run -node {nodename -command backup status
backup terminate
Not supported
bmc
Not supported
bmc reboot
Not supported
bmc status
Not supported
bmc test
Not supported
C
cdpd show-neighbors
system node run -node {nodename|local} -command network device-discovery show
cdpd show-stats
system node run -node {nodename|local} -command cdpd show-stats
cdpd zero stats
system node run -node {nodename|local} -command cdpd zero-stats
cf disable
cf disable
cf enable
cf enable
cf forcegiveback
Not supported
cf forcetakeover
cf forcetakeover
cf giveback
cf giveback
storage failover giveback
cf hw_assist
cf hwassist status
storage failover hwassist show
cf monitor all
cf monitor all
storage failover show -instance
cf partner
cf partner
storage failover show -fields partner-name
cf rsrctbl
cf rsrctbl
storage failover progress -table show
f status
cf status
cf takeover
cf takeover
storage failover takeover
charmap
vserver cifs character-mapping
cifs access
cifs access
vserver cifs access
cifs branchcache
cifs branchcache
vserver cifs branchcache
cifs changefilerpwd
cifs changefilerpwd
vserver cifs changefilerpwd
cifs domaininfo
vserver cifs {show instance|domain discovered-servers show -instance}
cifs gpresult
vserver cifs group-policy show-applied
cifs gpupdate
vserver cifs group-policy update
cifs homedir
vserver cifs home-directory
cifs nbalias
vserver cifs { add-netbios-aliases | remove-netbios-aliases | show -display-netbios-aliases }
cifs prefdc
vserver cifs domain preferred-dc
cifs restart
vserver cifs start
cifs sessions
vserver cifs sessions show
cifs setup
vserver cifs create
cifs shares
cifs shares vserver cifs share
cifs stat
statistics show -object cifs
cifs terminate
vserver cifs stop
cifs testdc
vserver cifs domain discovered-servers
cifs resetdc
cifs resetdc vserver cifs domain discovered-servers reset-servers
clone clear
Not supported
clone start
volume file clone create
clone stop
Not supported
clone status
volume file clone show
config clone
Not supported
config diff
Not supported
config dump
Not supported
config restore
Not supported
coredump
system node coredump
D
date
date { system | cluster } date { show | modify }
dcb priority
system node run -node nodename -command dcb priority
dcb priority show
system node run -node nodename -command dcb priority show
dcb show
system node run -node nodename -command dcb show
df
df
df [aggr name]
df -aggregate aggregate-name
df [path name]
df -filesys-name path- name
df -A
df -A
df -g
df -g df -gigabyte
df -h
df -h df -autosize
df -i
df -i
df -k
df -k df -kilobyte
df -L
df -L df -flexcache
df -m
df -m df -megabyte
df -r
df -r
df -s
df -s
df -S
df -S
df -t
df -t df -terabyte
df -V
df -V df -volumes
df -x
df -x df -skip-snapshot-lines
disk assign
disk assign storage disk assign
disk encrypt
system node run -node runnodename -command disk encrypt
disk fail
disk fail storage disk fail
disk maint
disk maint {start | abort | status | list } system node run -node {nodename|local} -command disk maint {start | abort | status | list }
disk remove
disk remove storage disk remove
disk replace
disk replace storage disk replace
disk sanitize
system node run -node nodename -command disk sanitize
disk scrub
disk show
storage disk show
disk simpull
system node run -node nodename -command disk simpull
disk simpush
system node run -node nodename -command disk simpush
disk zero spares
storage disk zerospares
disk_fw_update
system node image modify
dns info
dns show
download
system node image update
du [path name]
du -vserver vservername -path pathnamevolume file show-disk-usage -vserver vserver_name -path pathname
du -h
du -vserver vservername -path pathname -hvolume file show-disk-usage -vserver vserver_name -path pathname -h
du -k
du -vserver vservername -path pathname -kvolume file show-disk-usage -vserver vserver_name -path pathname -k
du -m
du -vserver vservername -path pathname -mvolume file show-disk-usage -vserver vserver_name -path pathname -m
du -r
du -vserver vservername -path pathname -rvolume file show-disk-usage -vserver vserver_name -path pathname -r
du -u
du -vserver vservername -path pathname -uvolume file show-disk-usage -vserver vserver_name -path pathname -u
dump
Not supportedYou must initiate the backup by using NDMP as described in tape backup documentation. For dump-to-null functionality, you must set the NDMP environment variable DUMP_TO_NULL.
E
echo
echo
ems event status
ems event status event status show
ems log dump
event log show -time >time-interval
ems log dump value
event log show
environment chassis
system node run -node {nodename|local} -command environment chassis
environment status
system node run -nodenodename -command environment status
environment shelf
Not supported
You must use the “storage shelf” command set.
environment shelf_log
environment shelf_log system node run -node {nodename|local} -command environment shelf_log
environment shelf_stats
system node run -node {nodename|local} -command environment shelf_stats
environment shelf_power_status
Not supported You must use the “storage shelf” command set.
environment chassis
environment chassis list-sensors
system node run -node {nodename|local} environment sensors show
exportfs
vserver export policy [rule]
exportfs -f
vserver export-policy cache flush
exportfs -o
vserver export-policy rule
exportfs -p
vserver export policy rule
exportfs -q
F-J
F
fcadmin config
system node run -node {nodename|local} -command fcadmin config
fcadmin link_stats
system node run -node {nodename|local} -command fcadmin link_stats
fcadmin fcal_stats
system node run -node {nodename|local} -command fcadmin fcal_stats
fcadmin device_map
system node run -node {nodename|local} -command fcadmin device_map
fcnic
Not supported
fcp config
network fcp adapter modify
fcp nameserver
fcp nameserver show vserver fcp nameserver show
fcp nodename
vserver fcp nodename
fcp ping
fcp ping-igroup show OR fcp ping-initiator show
vserver fcp ping-igroup show OR vserver fcp ping-initiator show
fcp portname
fcp portname show vserver fcp portname show
fcp show
vserver fcp show
fcp start
fcp start vserver fcp start
fcp stats
fcp stats fcp adapter stats
fcp status
vserver fcp status
fcp stop
fcp stop vserver fcp stop
fcp topology
network fcp topology show OR vserver fcp topology show
fcp wwpn-alias
fcp wwpn-alias vserver fcp wwpn-alias
fcp zone
fcp zone show
network fcp zone show
fcp dump
fcp adapter dump network fcp adapter dump
fcp reset
fcp adapter reset network fcp adapter reset
fcstat link_stats
system node run -node {nodename|local} -command fcstat link_stats
fcstat fcal_stats
system node run -node {nodename|local} -command fcstat fcal_stats
fcstat device_map
system node run -node {nodename|local} -command fcstat device_map
file reservation
volume file reservation
filestats
Not supported
flexcache
volume flexcache
fpolicy
fpolicy vserver fpolicy
fsecurity show
vserver security file-directory show
fsecurity apply
vserver security file-directory apply
fsecurity status
vserver security file-directory job-show
fsecurity cancel
vserver security file-directory job-stop
fsecurity remove-guard
vserver security file-directory remove-slag
ftp
Not supported
H
halt
system node halt -node nodename
halt -f
system node halt inhibit -takeover true
halt -d
system node halt -dump true
help
Note You must type the question mark (?) symbol to execute this command in ONTAP.
hostname
hostname system hostname
httpstat
Not supportedYou must use the statistics command.
I
if_addr_filter_info
system node run -note nodename -command if_addr_filter_info
ifconfig
network interfacenetwork {interface | port}
ifconfig -a
network interface show network {interface | port} show
ifconfig alias
network interface create
ifconfig down
network interface modify -status-admin down
ifconfig flowcontrol
network port modify -flowcontrol-admin
ifconfig mediatype
network port modify {-duplex-admin | -speed-admin}
ifconfig mtusize
network port modify -mtu
ifconfig netmask
network interface modify -netmask
ifconfig up
network interface modify -status-admin up
ifgrp create
network port ifgrp create
ifgrp add
network port ifgrp add -port
ifgrp delete
network port ifgrp remove-port
ifgrp destroy
network port ifgrp delete
ifgrp favor
For ONTAP 9 releases, create a failover group for the two ports using the network interface failover-groups create command. Then use the network interface modify command to set the favored home port with the -home-port option and set the -autorevert option to true.
Note Remove the ports from the ifgrp before adding them to the failover group. It is a best practice to use ports from different NICs. This practice also prevents EMS warnings regarding insufficient redundancy.
ifgrp nofavor
For ONTAP 9 releases, use the same procedure for failover groups.
ifgrp status
system node run -node {nodename|local} -command ifgrp status
ifgrp stat
system node run -node {nodename|local} -command ifstat ifgrp-port
ifgrp show
network port ifgrp show
ifinfo
system node run -node {nodename|local} -command ifinfo
ifstat
igroup add
igroup add lun igroup add
igroup alua
lun igroup modify -alua
igroup bind
igroup bind lun igroup bind
igroup destroy
igroup delete lun igroup delete
igroup create
igroup create lun igroup create
igroup remove
igroup remove lun igroup remove
igroup rename
igroup rename lun igroup rename
igroup set
igrouplun igroup set
igroup show
igroup show lun igroup show
igroup set ostype
igroup modify -ostype
igroup unbind
igroup unbind lun igroup unbind
ipsec
Not supported
iscsi alias
iscsi createvserver iscsi create OR
iscsi modify
vserver iscsi modify
iscsi connection
iscsi connection vserver iscsi connection
iscsi initiator
iscsi initiator vserver iscsi initiator
iscsi interface
iscsi interface vserver iscsi interface
iscsi isns
iscsi isns vserver iscsi isns
iscsi portal
iscsi portal vserver iscsi portal
iscsi security
iscsi security vserver iscsi security
iscsi session
iscsi session vserver iscsi session
iscsi show
iscsi show vserver iscsi show
iscsi start
iscsi start vserver iscsi start
iscsi stats
statistics {start|stop|show} -object object
Note Available at the advanced privilege level.
iscsi stop
iscsi stop vserver iscsi stop
K-O
K
key_manager
system node run -node {nodename|local} -command key_manager
keymgr
system node run -node {nodename|local} -command keymgr For management interface keys, you must use the “security certificates” commands.
L
license
license show
system license show
license add
license add
system license add -license-code V2_license_code
license delete
license delete
system license delete -package package_name
lock break
vserver locks break
lock break -h host
vserver locks break -client-address client-address
lock break -net network
vserver locks break -client-address-type ip address type
lock break -o owner
vserver locks break -owner-id owner-id
lock break -p protocol
vserver locks break -protocol protocol
lock status
vserver locks show
lock status -h host
vserver locks show -client-address client-address
lock status -o owner
vserver locks show -owner-id owner id
lock status -p protocol
vserver locks show -protocol protocol
logger
logger
system node run -node {nodename|local} -command logger
logout
exit
lun clone
lun comment
lun comment
lun config_check
Not supported
lun create
lun create –vserver vserver_name*
lun destroy
lun delete
lun map
lun map –vserver vserver_name
lun maxsize
lun maxsize
lun move
lun move
lun offline
lun modify -state offline
lun online
lun modify -state online
lun resize
lun resize
lun set
lun set
lun setup
lun create
lun share
Not supported
lun show
lun show
lun snap
Not supported
lun stats
statistics show -object lun
lun unmap
lun unmap
M
man
man
maxfiles
vol modify -max-number-of-files OR vol -fields files
mt
Not supported
You must use the storage tape command set.
N
nbtstat
vserver cifs nbtstat
ndmpd
{system | server} services ndmp
ndmpcopy
system node run -node {nodename|local} ndmpcopy
ndmpd on
ndmpd on system services ndmpd on
ndmpd off
ndmpd off system services ndmpd off
ndmpd status
{system | vserver} services ndmp status
ndmpd probe
{system | vserver} services ndmp probe
ndmpd kill
{system | vserver} services ndmp kill
ndmpd killall
{system | vserver} services ndmp kill-all
ndmpd password
{system | vserver} services ndmp password
ndmpd version
{system | vserver} services ndmp version
ndp
system node run -node {nodename|local} keymgr
netdiag
Not supportedYou must use the network interface or netstat commands.
netsat
system node run node nodename command netstat
network interface show -failover
network port vlan modify
Not supported
nfs off
nfs off vserver nfs off
nfs on
nfs on vserver nfs on
nfs setup
vserver nfs create OR vserver setup
nfs stat
statistics {start | stop | show} -object nfs*
nfs status
vserver nfs status
nfs vstorage
vserver nfs modify -vstorage
nfsstat
statistics show -object nfs*
O
orouted
Not supported
P-T
P
partner
Not supported
passwd
security login password
perf report -t
statistics {start | stop | show} -object perf
ping {host}
network ping {-node nodename | -lif lif-name} -destination
ping {count}
network ping {-node nodename | -lif lif-name} -count
ping -l interface
network ping -lif lif-name
ping -v
network ping -node {nodename | -lif lif-name} -verbose
ping -s
network ping -node {nodename | -lif lif-name} -show-detail
ping -R
network ping -node {nodename | -lif lif-name} -record-route
pktt delete
system node run -node {nodename|local} pktt delete
pktt dump
system node run -node {nodename|local} pktt dump
pktt list
system node run -node {nodename|local} pktt list
pktt pause
system node run -node {nodename|local} pktt pause
pktt start
system node run -node {nodename|local} pktt start
pktt status
system node run -node {nodename|local} pktt status
pktt stop
system node run -node {nodename|local} pktt stop
portset add
portset add lun portset add
portset create
portset create lun portset create
portset delete
portset delete lun portset delete
portset remove
portset remove lun portset remove
portset show
portset show lun portset show
priority hybrid-cache default
Not supported
priority hybrid-cache set
volume modify -volume volume_name -vserver vserver_name -caching-policy policy_name
priority hybrid-cache show
volume show -volume volume_name -vserver vserver_name -fields caching -policy
priv set
set -privilege
Q
qtree create
qtree create volume qtree create
qtree oplocks
qtree oplocks volume qtree oplocks
qtree security
qtree security volume qtree security
qtree status
qtree show volume qtree show
qtree stats
qtree statisticsvolume qtree statistics
quota allow
quota modify -state volume quota modify -state on
quota disallow
quota modify -statevolume quota modify -state off
quota off
quota off volume quota off
quota on
quota on volume quota on
quota report
quota report volume quota report
quota resize
quota resize volume quota resize
quota status
quota show volume quota show
quota logmsg
volume quota show -fields logging, logging -interval
R
radius
Not supported
rdate
Not supported
rdfile
Not supported
reallocate off
reallocate off
reallocate measure
reallocate measure
reallocate on
reallocate on
reallocate quiesce
reallocate quiesce
reallocate restart
reallocate restart
reallocate schedule
reallocate schedule
reallocate start
reallocate start
reallocate status
reallocate show
reallocate stop
reallocate stop
reboot
reboot
system node reboot -node nodename
reboot -d
reboot -d
system node reboot -dump true -node nodename
reboot -f
reboot -f
reboot -inhibit-takeover true -node nodename
restore
Not supported
You must initiate the restore by using NDMP as described in tape backup documentation.
restore_backup
system node restore-backup
revert_to
system node revert-to node nodename -version
rlm
Not supported
route add
route add
network route create
route delete
route delete
network route delete
route -s
route show
network route show
Note The network routing-groups command family is deprecated in ONTAP 9 and no longer supported beginning with 9.4.
S
sasadmin adapter_state
system node run -node {nodename|local} -command sasadmin adapter_state
sasadmin channels
system node run -node {nodename|local} -command sasadmin channels
sasadmin dev_stats
system node run -node {nodename|local} -command sasadmin dev_stats
sasadmin expander
system node run -node {nodename|local} -command sasadmin expander
sasadmin expander_map
system node run -node {nodename|local} -command sasadmin expander_map
sasadmin expander_phy_state
system node run -node {nodename|local} -command sasadmin expander_phy_state
sasadmin shelf
storage shelf
sasadmin shelf_short
storage shelf
sasstat dev_stats
system node run -node {nodename|local} -command sasstat dev_stats
sasstat adapter_state
system node run -node {nodename|local} -command sasstat adapter_state
sasstat expander
system shelf show -port
sasstat expander_map
storage shelf show -module
sasstat expander_phy_state
system node run -node {nodename|local} sasstat expander_phy_state
sasstat shelf
storage shelf
savecore
system node coredump save-all
savecore -i
system node coredump config show -i
savecore -l
system node coredump show
savecore -s
system node coredump status
*savecore -*w
Not supported
savecore -k
system node coredump delete-all -type unsaved-kernel
sectrace add
vserver security trace create
sectrace delete
vserver security trace delete
sectrace show
vserver security trace filter show
sectrace print-status
vserver security trace trace-result show
secureadmin addcert
security certificate install
secureadmin disable ssh
security login modify
secureadmin disable ssl
security ssl modify
secureadmin enable ssl
security ssl modify
secureadmin setup
security
secureadmin setup ssh
security ssh {add|modify}
secureadmin setup ssl
security ssl {add|modify}
secureadmin enable ssh
secureadmin status ssh
security login show
secureadmin status ssl
security ssl show
setup
Not supported
shelfchk
showfh
sis config
sis off
security login show
sis on
security ssl show
sis revert_to
Not supported
sis start
showfh
volume file show-filehandle
sis stop
sis off
volume efficiency off
smtape
sis on
volume efficiency on
snap autodelete
sis policy
snap create
sis revert_to
volume efficiency revert-to
snap delete
snap delete
volume snapshot delete
snap delta
Not supported
snap list
snap show
volume snapshot show
snap reclaimable
volume snapshot compute -reclaimable
snap rename
snap rename
volume snapshot rename
snap reserve
volume {modify|show} --fields percent-snapshot-space --volume volume-name
storage aggregate {modify|show} --fields percent-snapshot-space --aggregate aggregate-name
snap restore
snap restore
volume snapshot restore
snap sched
volume snapshot policy
snap reclaimable
volume snapshot compute-reclaimable
snapmirror abort
snapmirror abort
snapmirror break
snapmirror break
snapmirror destinations
snapmirror list-destinations
snapmirror initialize
snapmirror migrate
Not supported
snapmirror off
Not supported
snapmirror on
Not supported
snapmirror quiesce
snapmirror quiesce
snapmirror release
snapmirror release
snapmirror resume
snapmirror resume
snapmirror resync
snapmirror resync
snapmirror status
snapmirror show
snapmirror throttle
Not supported
snapmirror update
snapmirror update
snmp authtrap
snmp authtrap
snmp community
snmp community
snmp contact
snmp contact
snmp init
snmp init
snmp location
snmp location
snmp traphost
snmp traphost
snmp traps
event route show -snmp-support true
software delete
system node image package delete
software get
system node image get
software install
software list
system node image package show
software update
source
Not supported
sp reboot
system service-processor reboot-sp
sp setup
system service-processor network modify
sp status
system service-processor show
sp status -d
system node autosupport invoke-splog
sp status -v
sp update
system service-processor image update
sp update-status
system service-processor image update-progress
statit
statistics {start|stop|show} -preset statit
stats
statistics {start|stop|show} –object object
storage aggregate copy
Not supported
storage aggregate media_scrub
system node run -node nodename -command aggr media_scrub
storage aggregate snapshot
Not supported
storage aggregate split
Not supported
storage aggregate undestroy
Not supported
storage alias
storage tape alias set
storage array
storage array
storage array modify
storage array remove
storage array remove-port
storage array port remove
storage array show
storage array show
storage array show-config
storage array config show
storage array show luns
Not supported
storage array show-ports
storage array port show
storage disable adapter
system node run -node {nodename|local} -command storage disable adapter
storage download acp
Storage shelf acp firmware update
storage download shelf
storage firmware download
storage enable adapter
system node run -node {nodename|local} -command storage enable adapter
storage load balance
storage load show
storage load show
storage show acp
system node run -node {nodename|local} -command storage show acp
storage show adapter
system node run -node {nodename|local} -command storage show adapter
storage show bridge
storage bridge show
storage show disk
storage show disk
storage disk show
storage show expander
storage shelf
storage show fabric
system node run -node {nodename|local} -command storage show fabric
storage show fault
system node run -node nodename -command storage show fault
storage show hub
system node run -node {nodename|local} -command storage show hub
storage show initiators
system node run -node {nodename|local} -command storage show initiators
storage show mc
storage tape show-media-changer
storage show port
storage switch
storage show shelf
storage shelf
storage show switch
storage switch show
storage show tape
storage tape show-tape-drive
storage stats tape
statistics show -object tape
storage stats tape zero
statistics {start|stop|show} -object tape
storage unalias
storage tape alias clear
sysconfig
Not supported
sysconfig -a
system node run -node {nodename|local} -command sysconfig -a
sysconfig -A
system node run -node {nodename|local} -command sysconfig -A
sysconfig -ac
system controller config show-errors -verbose
sysconfig -c
system controllers config-errors show
sysconfig -d
system node run -node {nodename|local} -command sysconfig -d
sysconfig -D
system controller config pci show-add-on devices
sysconfig -h
system node run -node {nodename|local} -command sysconfig -h
sysconfig -m
syconfig -M
system node run -node {nodename|local} -command sysconfig -M
sysconfig -p
Not supported
You must use the following commands as alternatives:
  • Hypervisor information: system node virtual-machine hypervisor show
  • System disks backing stores: system node virtual-machine instance show-system-disks
  • Virtual disks backing information: storage disk show -virtual-machine-disk-info
sysconfig -P
system controller config pci show-hierarchy
sysconfig -r
Not supported
To view disk information, you must use the following commands:
  • File system disks: storage aggregate showstatus
  • Spare disks: storage aggregate show-sparedisks
  • Broken disks: storage disk show -broken
  • Disks in the maintenance center: storage disk show -maintenance
sysconfig -t
storage tape show
sysconfig -v
system node run -node nodename -command sysconfig -v
sysconfig -V
system node run -node {nodename|local} -command sysconfig -V
sysstat
statistics {start|stop|show} -preset systat
system health alert
system health alert
system health autosupport
system health config
system health node-connectivity
system health policy
system health status
system health subsystem show
T
timezone
timezone
traceroute -m
traceroute -m
network traceroute { -node nodename | -lif lif-name } -maxttl integer
traceroute -n
traceroute -n
network traceroute -node {nodename| -lif lif-name} -numeric true
traceroute -p
traceroute -p
network traceroute { -node nodename | -lif lif-name } --port integer
traceroute -q
traceroute -q
network traceroute { -node nodename | -lif lif-name } -nqueries integer
traceroute -s
Not supported
traceroute -v
traceroute -v
network traceroute { -node nodename | -lif lif-name } -verbose [ true ]
traceroute -w
traceroute -w
network traceroute { -node nodename | -lif lif-name } -waittime integer
U-Z
U
ucadmin
system node hardware unified-connect
ups
Not supported
uptime
system node show -fields uptime
useradmin domainuser add
security login create
useradmin domainuser delete
security login delete
useradmin domainuser list
security login show
useradmin domainuser load
Not supported Use "vserver cifs users-and-groups" command set.
useradmin group add
security login role create
useradmin group delete
security login role delete
useradmin group list
security login role show
useradmin group modify
security login role modify
useradmin role add
useradmin role delete
useradmin role list
useradmin role modify
useradmin user add
useradmin user delete
useradmin user list
security login show
useradmin user modify
V
version -b
version -b
OR system image show
version -v
version -v
vfiler
Not supported
vfiler run
vserver
vfiler start
vserver start
vfiler stop
vserver stop
vfiler status
vserver show
vfiler disallow
vserver modify -disallowed-protocols
vlan add
network port vlan create
vlan create
vlan delete
network port vlan delete
vlan modify
Not supported
vlan stat
system node run -node nodename -command vlan stat
vmservices
system node run -node {nodename|local} vmservices
volume add
Not supported
volume autosize
volume autosize
volume clone
volume clone
volume clone split
volume clone split
volume container
volume show -fields aggregate
volume copy
Not supportedYou must use one of the following methods as described in logical storage documentation:
  • Create a FlexClone volume of the original volume, then move the volume to another aggregate by using the volume move command.
  • Replicate the original volume using SnapMirror, then break the SnapMirror relationship to make a read-write volume copy.
volume create
volume create
vol destroy
volume destroy
volume file fingerprint
Not supported
volume media_scrub
Not supported
volume migrate
Not supported
vol mirror
Not supported
volume move
volume move
volume offline
volume offline
volume online
volume online
volume options
volume {show | modify}
volume quota allow
Not supported
volume quota disallow
Not supported
volume rename
volume rename
volume restrict
volume restrict
volume scrub
Not supported
volume size
volume size
volume snapshot delta
Not supported
volume snapshot reserve
Not supported
Alternative commands include the following:
  • For volumes, use: the "volume show -fields percent-snapshot-space" and "volume modify -volume volumename -percent-snapshot-space percent" commands.
  • For aggregates, use the "storage aggregate show -fields percent-snapshot-space" and "storage aggregate modify -aggregate aggregate name -percent-snapshot-space percent" commands.
volume split
Not supported
volume status
volume show
volume verify
Not supported
volume wafliron
Not supported
vscan
vserver vscan
vserver cifs adupdate
Not supported
vserver cifs broadcast
Not supported
vserver cifs comment
Not supported
vserver cifs top
Not supported
vserver iscsi ip_tpgroup add
Not supported
vserver iscsi ip_tpgroup create
Not supported
vserver iscsi ip_tpgroup destroy
Not supported
vserver iscsi ip_tpgroup remove
Not supported
vserver iscsi ip_tpgroup show
Not supported
vserver iscsi tpgroup alua set
Not supported
vserver iscsi tpgroup alua show
Not supported
vserver services name-service dns flush
Not supported
W
wrfile
Not supported
Y
ypcat
Not supported
ypgroup
Not supported
ypmatch
Not supported
ypwhich
Not supported
