How to interpret the clustered Data ONTAP commands, options, and configuration files maps for 7-Mode administrators
If you are moving from Data ONTAP running in 7-Mode to clustered Data ONTAP, you might find it handy to refer to the command maps, which show the clustered Data ONTAP equivalents of 7-Mode commands, options, and configuration files.
What mapping information is included
The Command Map for 7-Mode Administrators includes the following mappings of 7-Mode commands, options, and configuration files to their clustered Data ONTAP equivalents:
How to interpret 7-Mode-compatible shortcut commands
Although the Data ONTAP command-line interface (CLI) is significantly reorganized for cluster operations, many of the commands have 7-Mode-compatible shortcut versions that require no change to scripts or other automated tasks. These shortcut versions are listed first and in bold in the tables here. Shortcut versions that are not 7-Mode-compatible are listed next, followed by the full, long-form version of the commands:
| 7-Mode command | Clustered Data ONTAP command |
If no bold shortcut is listed, a 7-Mode-compatible version is not available. Not all forms of the commands are shown in the table. The CLI is extremely flexible, allowing multiple abbreviated forms.
Understanding the different clustered Data ONTAP shells for CLI commands
A cluster has three different shells for CLI commands:
The clustershell is the native shell, started automatically when you log in to the cluster.
It provides all the commands you need to configure and manage the cluster.
The nodeshell is a special shell that enables you to run a subset of 7-Mode commands.
These commands take effect only at the node level. You can switch from the clustershell to a nodeshell session to run nodeshell commands interactively, or you can run a single nodeshell command from the clustershell. You can recognize a command as a nodeshell command if it has the (long) form
system node run -node {nodename|local} commandname. -
The systemshell is a low-level shell used only for diagnostic and troubleshooting purposes.
It is not intended for general administrative purposes. Access the systemshell only with guidance from technical support.
Switching to nodeshell
When you see a 7-Mode-compatible shortcut version of a nodeshell command, it is assumed that you are running the command from the nodeshell. To switch to the nodeshell, enter the following:
Other forms of the nodeshell command must be run from the clustershell.
Where to go for more information
| If you want to… | For more information… |
Use clustershell commands |
Use nodeshell commands |
Execute CLI commands, navigate CLI command directories, set values in the CLI, and use queries, patterns, and wildcards |
