How 7-Mode options map to ONTAP commands
In Data ONTAP operating in 7-Mode, you execute the options command to set configurable storage system software options. In ONTAP, you use command parameters to set these options. You can use the provided tables to view how 7-Mode commands map to ONTAP commands.
In the “7-Mode command” column, the base options command is not shown, for the sake of clarity. Where you see acp.domain, the actual long form of the command is options acp.domain.
The “Understanding the 7-Mode to clustered Data ONTAP command mapping” section contains information about how the tables in this chapter are organized.
A-E
A
| 7-Mode option | Clustered Data ONTAP command |
Not supported |
Not supported |
Not supported |
Not supported |
B
Not supported |
C
| 7-Mode option | Clustered Data ONTAP command | ||
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
D
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
E
F-K
F
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
H
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
I
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
K
Not supported |
Not supported |
O-Q
L
ldap client schema modify -nis-netgroup-triple-attribute
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
N
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
`Not supported |
`Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
P
Not supported |
Not supported |
Q
Not supported |
R
All RAID options have 7-Mode-compatible nodeshell shortcuts of the form options option_name.
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
S-Z
S
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
ssl.enable |
Not supported |
T
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
V
Not supported |
Not supported |
Not supported |
W
Not supported |
Not supported |
