Mounting Solaris host LUNs with Solaris Volume Manager after transition
After transitioning Solaris host LUNs with Solaris Volume Manager from ONTAP operating in 7-Mode to clustered ONTAP, you must mount the LUNs.
For copy-based transitions, you perform these steps after completing the Storage Cutover operation in the 7-Mode Transition Tool (7MTT).
For copy-free transitions, you perform these steps after the Import Data & Configuration operation in the 7MTT is complete.
Discover your new clustered ONTAP LUNs by rescanning the host.
Identify the FC host ports (type fc-fabric):
#cfgadm –l -
Unconfigure the first fc-fabric port:
#cfgadm –c unconfigure c1 -
Unconfigure the second fc-fabric port:
#cfgadm –c unconfigure c2 -
Repeat the steps for other fc-fabric ports.
Verify the host ports and their attached devices:
# cfgadm –al -
Reload the driver:
# devfsadm –Cv# devfsadm –i iscsi
Verify that your clustered ONTAP LUNs have been discovered:
sanlun lun show-
The
lun-pathnamevalues for the clustered ONTAP LUNs should be the same as thelun-pathnamevalues for the 7-Mode LUNs prior to transition. -
The
modecolumn should display “C” instead of “7”.
# sanlun lun show controller(7mode)/ device host lun vserver(Cmode) lun-pathname filename adapter protocol size mode -------------------------------------------------------------------------------------------------------------------------- vs_sru17_5 /vol/zfs/zfs2 /dev/rdsk/c5t600A0980383030444D2B466542485935d0s2 scsi_vhci0 FCP 6g C vs_sru17_5 /vol/zfs/zfs1 /dev/rdsk/c5t600A0980383030444D2B466542485934d0s2 scsi_vhci0 FCP 6g C vs_sru17_5 /vol/ufs/ufs2 /dev/rdsk/c5t600A0980383030444D2B466542485937d0s2 scsi_vhci0 FCP 5g C vs_sru17_5 /vol/ufs/ufs1 /dev/rdsk/c5t600A0980383030444D2B466542485936d0s2 scsi_vhci0 FCP 5g C
Import disk sets into existing Solaris Volume Manager configurations, using the same disk set name:
metaimport -s set-name# metaimport -s svm Drives in regular diskset including disk c0t60A98000383035356C2447384D39654Ad0: c0t60A98000383035356C2447384D39654Ad0 c0t60A98000383035356C2447384D396548d0 More info: metaimport -r -v c0t60A98000383035356C2447384D39654Ad0 # metastat -s svm svm/d2: Concat/Stripe Size: 10452992 blocks (5.0 GB) Stripe 0: Device Start Block Dbase Reloc /dev/dsk/c0t60A98000383035356C2447384D396548d0s0 0 No Yes svm/d1: Concat/Stripe Size: 10452992 blocks (5.0 GB) Stripe 0: Device Start Block Dbase Reloc /dev/dsk/c0t60A98000383035356C2447384D39654Ad0s0 0 No Yes Device Relocation Information: Device Reloc Device ID /dev/dsk/c0t60A98000383035356C2447384D396548d0 Yes id1,sd@n60a98000383035356c2447384d396548 /dev/dsk/c0t60A98000383035356C2447384D39654Ad0 Yes id1,sd@n60a98000383035356c2447384d39654a -
Run file system check:
fsck -F ufs /dev/md/svm/rdsk/d1# fsck -F ufs /dev/md/svm/rdsk/d1 ** /dev/md/svm/rdsk/d1 ** Last Mounted on /d1 ** Phase 1 - Check Blocks and Sizes ** Phase 2 - Check Pathnames ** Phase 3a - Check Connectivity ** Phase 3b - Verify Shadows/ACLs ** Phase 4 - Check Reference Counts ** Phase 5 - Check Cylinder Groups 3 files, 1573649 used, 3568109 free (13 frags, 446012 blocks, 0.0% fragmentation)
Manually mount each of the devices using the
mountcommand.# /sbin/mount -F ufs -o largefiles /dev/md/svm/dsk/d1 /d1 # /sbin/mount -F ufs -o largefiles /dev/md/svm/dsk/d2 /d2
Verify the mount point:
df -ah
