ONTAP 7-Mode Transition
NFS transition: supported and unsupported configurations, and required manual steps
Contributors netapp-ivanad
Some NFS configurations are not transitioned to ONTAP because they are not supported in ONTAP, there are functionality differences from 7-Mode, or they must be manually transitioned. You should verify all of the precheck errors and warning messages to evaluate the impact of such configurations on transition.
Supported configurations for transition
At a high level, the following NFS configurations are transitioned by the 7-Mode Transition Tool:
  • NFS options:
    • nfs.udp.xfersize
    • nfs.v4.id.domain
    • nfs.v4.acl.max.aces
    • nfs.tcp.xfersize
    • nfs.rpcsec.ctx.high
    • nfs.rpcsec.ctx.idle
    • nfs.response.trigger
    • wafl.default_nt_user
    • nfs.mount_rootonly
    • nfs.tcp.enable
    • nfs.udp.enable
    • nfs.response.trace
    • nfs.v4.read_delegation
    • nfs.v4.write_delegation
    • nfs.v4.acl.enable
    • nfs.vstorage.enable
    • nfs.v3.enable
    • nfs.v4.enable
  • NFS export rule:
    If the export rule is configured with the -actual option, the exported path (alias path) is ignored and the export rule is configured with the actual path.
  • Export rules with Kerberos security krb5p
See the precheck results for details about these NFS configurations.
Unsupported configurations in ONTAP
The following NFS configurations are not supported in ONTAP:
  • Subvolume NFS exports other than qtree-level NFS exports
  • WebNFS
  • PC-NFS
  • NFSv2
  • Fencing of NFS clients from one or more file system paths
  • Some NFS options
    See the precheck warning messages for a complete list of unsupported options.
Configurations that must be manually transitioned
There are some NFS configurations that are supported in ONTAP, but are not transitioned by the 7-Mode Transition Tool.
The following NFS configurations generate a warning message in the precheck operation, and you must manually apply the configurations on the SVM:
  • NFS audit configuration
  • NFS options:
    • rpc.nsm.tcp.port
    • rpc.nsm.udp.port
    • rpc.mountd.tcp.port
    • rpc.mountd.udp.port
    • nfs.export.neg.timeout
    • nfs.export.pos.timeout
    • nfs.export.harvest.timeout Use the vserver nfs modify command to modify the configuration of an NFS-enabled storage virtual machine (SVM).
  • Kerberos configuration
Configurations that are functionally different in ONTAP
The following NFS configurations are functionally different in ONTAP:
  • NFS export rules
  • NFS export access cache
  • NFS diagnostic commands
  • Support for the showmount command
  • NFS Kerberos encryption
  • NLM version support
Related information
