Failed to boot the 7-Mode controller in maintenance mode
The export and halt operation fails with the error message: Failed to boot the 7-Mode controller in maintenance mode. You must manually halt and boot the controller in the maintenance mode and rerun the operation.
Workaround
Halt the 7-Mode storage system:
halt -f -t 0 -
At the LOADER prompt, record the values set for the
bootarg.init.console_mutedandbootarg.init.console_level bootboot parameters:printenv bootarg.init.console_mutedprintenv bootarg.init.console_level -
Disable the console messages by setting the following boot parameters:
setenv bootarg.init.console_muted "true"setenv bootarg.init.console_level "-1" -
From the 7-Mode Transition Tool, rerun the export and halt operation.
From the 7-Mode storage system, set the boot parameters to their original values, as recorded in Step 2:
If the boot parameters are… Enter the following commands… Not set previously with any value (undefined)
unsetenv bootarg.init.console_mutedunsetenv bootarg.init.console_levelSet with a value previously
unsetenv bootarg.init.console_muted "original_value"unsetenv bootarg.init.console_level "original_value"
