Tool installation fails with an incompatible OS error
Installation of the 7-Mode Transition Tool fails with the error message 7-Mode Transition Tool is not compatible with this version of Windows.
Workaround
Right-click the
NetApp_7ModeTransitionTool_Setup.exefile, and then select Properties. -
In the Compatibility tab, click Change settings for all users.
Verify that the Run this program in compatibility mode for: check box is not selected, and then click Apply.
