ONTAP 7-Mode Transition
Tools and documentation required for copy-free transition
Contributors netapp-ivanad
The Config Advisor is the required tool for copy-free transition. You should use Config Advisor to verify the cabling of the disk shelves. Additional documentation is also available for SAN host remediation.
Config Advisor
You should use the “Transition” execution profile in Config Advisor to verify the cabling after the 7-Mode disk shelves are connected to the target cluster nodes.
Documentation
Describes the pre-transition and post-transition steps that have to be performed on SAN hosts when transitioning using copy-free transition.
