Syntax and options
Inventory Collection Tool (ICT) commands collect configuration and inventory information from controllers and hosts that are specified either in the command-line interface (CLI) or in a text file that contains system details. You can use syntax and options with the ICT commands.
Syntax
ict --cmd collect [--output <inventory.xml>] <uri> [<uri> …] -
ict --cmd collect [--output <inventory.xml>] --input <credential_file.txt> -
ict --cmd generate-fc-zones --source-filers <filer-ip>[,<filer-ip>] --dest-svm <cluster-name:svm-name> --fc-switches <switch-ip>[:<vsan-id>][,<switch-ip>[:<vsan-id>] … ] <inventory_xml> [<inventory_xml> …] -
ict --cmd generate-fc-zones --source-filers <filer-ip>[<filer-ip>] --dest-svm <cluster-name:svm-name> --fc-switches <switch-ip>[:<vsan-id>][,<switch-ip>[:<vsan-id>] … ] --fc-switches-target <switch-ip>[:<vsan-id>][,<switch-ip>[:<vsan-id>] … ] <inventory_xml> [<inventory_xml> …] -
ict --help -
ict --version
Options
The text file must contain system details of each system in a separate line:
uri1
uri2
uri3
If a password is * or omitted either in the CLI or text file, then the user is prompted to enter a password in the CLI. The following options are available to run the ICT:
--helpShows the help message and exits.
--versionPrints the tool version and exits.
--cmd [collect|generate-fc-zones]collect: Collects configuration and inventory information from controllers and hosts.
generate-fc-zones: Generates FC Zone planner document on a given inventory.
--output <filename[.xml[.gz]]>Specifies the location where the files are generated. If the file name is suffixed with “.gz” , then the file is compressed. This option generates two files (reports): Inventory Report and Inventory Report Workbook.
--input <credentials_file.txt>Specifies the location where the file with system credentials is saved. This option is not used in
--cmd generate-fc-zones.Only ASCII encoded text file is supported. -
uri format(
ontap|windows|vmware|linux|cisco|brocade)://[(<user>|<domain_user>)[:(<password>|*)]@](<hostname>|<ip>)Specifies the system type, IP address, and credentials of the controller or host. If the password provided is
*, or if no passwords are provided, then the user is prompted to enter a password in the command line. -
--source-filersSpecifies comma-separated IP address of the source controllers to be used in generating the FC Zone Plan.
--dest-svmSpecifies the destination clustered Data ONTAP SVM formatted as
cluster-name:svm-nameto be used in generating the FC Zone Plan. -
--fc-switchesLists the FC switches for which the FC Zone Plan has to be generated. It is a comma-separated list of switch identifiers. For Cisco, FC switches should be formatted as
switch-ip:vsan-idand for Brocade, FC switches should be formatted asswitch-ip. For example, 10.61.187.6:200,10.61.187.7:200 (Cisco) or 10.61.187.4,10.61.187.5 (Brocade) -
--fc-switches-targetSpecifies the list of FC switches (connected to the cluster) for which the FC Zone Plan has to be generated. It is a comma-separated list of target switch identifiers that are listed in the same sequence as origin FC switches (--fc-switches). The FC zoning script is generated for each origin switch added to the fc-switches parameter list. This is an optional parameter.
For FC Zone Planner, input inventory XMLs are given as unnamed arguments.
