System requirements for running the Inventory Collect Tool
You can download and run the Inventory Collect Tool on a Windows system. The Windows system must have the required configuration to run the Inventory Collect Tool.
The Windows system must be one of the following:
64-bit Windows 7 Enterprise
Windows Server 2008 R2 Enterprise with SP1 or later
Windows Server 2012 R2 Standard
You can use a Windows virtual machine that meets the required software and hardware requirements to install the Inventory Collect Tool. |
Dual-core x64 processor (1.0 GHz or more)
4-GB RAM
40-GB HDD
