Prepare for netboot
Contributors netapp-pcarriga netapp-aoife netapp-aherbin
After you physically rack node3 and node4 later in the procedure, you might need to netboot them. The term netboot means you are booting from an ONTAP image stored on a remote server. When preparing for netboot, you must put a copy of the ONTAP 9 boot image onto a web server that the system can access.
Before you begin
  • Verify that you can access a HTTP server with the system.
  • Refer to References to link to the NetApp Support Site and download the necessary system files for your platform and the correct version of ONTAP.
About this task
You must netboot the new controllers if they do not have the same version of ONTAP 9 installed on them that is installed on the original controllers. After you install each new controller, you boot the system from the ONTAP 9 image stored on the web server. You can then download the correct files to the boot media device for subsequent system boots.
However, you do not need to netboot the controllers if the same version of ONTAP 9 is installed on them that is installed on the original controllers. If so, you can skip this section and proceed to Stage 3: Install and boot node3.
Steps
  1. Access the NetApp Support Site to download the files used for performing the netboot of the system.
  2. Download the appropriate ONTAP software from the software download section of the NetApp Support Site and store the <ontap_version>_image.tgz file on a web-accessible directory.
  3. Change to the web-accessible directory and verify that the files you need are available.
    For…​ Then…​
    FAS/AFF8000 series systems
    Extract the contents of the <ontap_version>_image.tgz file to the target directory:
    tar -zxvf <ontap_version>_image.tgz
    Note If you are extracting the contents on Windows, use 7-Zip or WinRAR to extract the netboot image.
    Your directory listing should contain a netboot folder with a kernel file:
    netboot/kernel
    All other systems
    Your directory listing should contain the following file:
    NOTE: You do not need to extract the contents of the <ontap_version>_image.tgz file.
    You will use information in the directories in Stage 3.
What's next?
After preparing for netboot, relocate non-root aggregates from node1 to node2.
