Configure SNMPv3 for switch log collection
Follow this procedure to configure SNMPv3, which supports switch log collection and Switch Health Monitoring (SHM).
The following commands configure an SNMPv3 username on NVIDIA SN2100 switches:
For no authentication:
net add snmp-server username SNMPv3_USER auth-none
For MD5/SHA authentication:
net add snmp-server username SNMPv3_USER [auth-md5|auth-sha] AUTH-PASSWORD
For MD5/SHA authentication with AES/DES encryption:
net add snmp-server username SNMPv3_USER [auth-md5|auth-sha] AUTH-PASSWORD [encrypt-aes|encrypt-des] PRIV-PASSWORD
The following command configures an SNMPv3 username on the ONTAP side:
cluster1::*> security login create -user-or-group-name SNMPv3_USER -application snmp -authentication-method usm -remote-switch-ipaddress ADDRESS
The following command establishes the SNMPv3 username with SHM:
cluster1::*> system switch ethernet modify -device DEVICE -snmp-version SNMPv3 -community-or-username SNMPv3_USER
Set up the SNMPv3 user on the switch to use authentication and encryption:
net show snmp status
Show example
cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 4318 Version 1 and 2c Community String Configured Version 3 Usernames Not Configured --------------------------------- ---------------- cumulus@sw1:~$ cumulus@sw1:~$ net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password> cumulus@sw1:~$ net commit --- /etc/snmp/snmpd.conf 2020-08-02 21:09:34.686949282 +0000 +++ /run/nclu/snmp/snmpd.conf 2020-08-11 00:13:51.826126655 +0000 @@ -1,26 +1,28 @@ # Auto-generated config file: do not edit. # agentaddress udp:@mgmt:161 agentxperms 777 777 snmp snmp agentxsocket /var/agentx/master createuser _snmptrapusernameX +createuser SNMPv3User MD5 <password> AES <password> ifmib_max_num_ifaces 500 iquerysecname _snmptrapusernameX master agentx monitor -r 60 -o laNames -o laErrMessage "laTable" laErrorFlag != 0 pass -p 10 1.3.6.1.2.1.1.1 /usr/share/snmp/sysDescr_pass.py pass_persist 1.2.840.10006.300.43 /usr/share/snmp/ieee8023_lag_pp.py pass_persist 1.3.6.1.2.1.17 /usr/share/snmp/bridge_pp.py pass_persist 1.3.6.1.2.1.31.1.1.1.18 /usr/share/snmp/snmpifAlias_pp.py pass_persist 1.3.6.1.2.1.47 /usr/share/snmp/entity_pp.py pass_persist 1.3.6.1.2.1.99 /usr/share/snmp/entity_sensor_pp.py pass_persist 1.3.6.1.4.1.40310.1 /usr/share/snmp/resq_pp.py pass_persist 1.3.6.1.4.1.40310.2 /usr/share/snmp/cl_drop_cntrs_pp.py pass_persist 1.3.6.1.4.1.40310.3 /usr/share/snmp/cl_poe_pp.py pass_persist 1.3.6.1.4.1.40310.4 /usr/share/snmp/bgpun_pp.py pass_persist 1.3.6.1.4.1.40310.5 /usr/share/snmp/cumulus-status.py pass_persist 1.3.6.1.4.1.40310.6 /usr/share/snmp/cumulus-sensor.py pass_persist 1.3.6.1.4.1.40310.7 /usr/share/snmp/vrf_bgpun_pp.py +rocommunity cshm1! default rouser _snmptrapusernameX +rouser SNMPv3User priv sysobjectid 1.3.6.1.4.1.40310 sysservices 72 -rocommunity cshm1! default net add/del commands since the last "net commit" ================================================ User Timestamp Command ---------- -------------------------- ----------------------------------------------------------------------------- SNMPv3User 2020-08-11 00:13:51.826987 net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password> cumulus@sw1:~$ cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 24253 Version 1 and 2c Community String Configured Version 3 Usernames Configured <---- Configured here --------------------------------- ---------------- cumulus@sw1:~$
Set up the SNMPv3 user on the ONTAP side:
security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212
Show example
cluster1::*> security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212 Enter the authoritative entity's EngineID [remote EngineID]: Which authentication protocol do you want to choose (none, md5, sha, sha2-256) [none]: md5 Enter the authentication protocol password (minimum 8 characters long): Enter the authentication protocol password again: Which privacy protocol do you want to choose (none, des, aes128) [none]: aes128 Enter privacy protocol password (minimum 8 characters long): Enter privacy protocol password again:
Configure SHM to monitor with the new SNMPv3 user:
system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance
Show example
cluster1::*> system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance Device Name: sw1 (b8:59:9f:09:7c:22) IP Address: 10.231.80.212 SNMP Version: SNMPv2c Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: cshm1! Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 4.4.3 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 <---- serial number to check RCF Version: MSN2100-RCF-v1.9X6-Cluster-LLDP Aug-18-2022 cluster1::*> cluster1::*> system switch ethernet modify -device "sw1 (b8:59:9f:09:7c:22)" -snmp-version SNMPv3 -community-or-username SNMPv3User
Verify that the serial number to be queried with the newly created SNMPv3 user is the same as detailed in the previous step once the SHM polling period has completed.
system switch ethernet polling-interval show
Show example
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance Device Name: sw1 (b8:59:9f:09:7c:22) IP Address: 10.231.80.212 SNMP Version: SNMPv3 Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: SNMPv3User Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 4.4.3 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 <---- serial number to check RCF Version: MSN2100-RCF-v1.9X6-Cluster-LLDP Aug-18-2022
