Recabling the system
After running diagnostics, you must recable the controller module's storage and network connections.
Recable the system.
Verify that the cabling is correct by using Config Advisor.
Download and install Config Advisor from the NetApp Support Site.
Enter the information for the target system, and then click Collect Data.
Click the Cabling tab, and then examine the output.
Make sure that all disk shelves are displayed and all disks appear in the output, correcting any cabling issues you find.
Check other cabling by clicking the appropriate tab, and then examining the output from Config Advisor.
