Configure a connection between Workflow Automation and Active IQ Unified Manager
You can configure a secure connection between OnCommand Workflow Automation (WFA) and Unified Manager. Connecting to Workflow Automation enables you to use protection features such as SnapMirror and SnapVault configuration workflows, as well as commands for managing SnapMirror relationships.
The installed version of Workflow Automation must be 5.1.1P6 or greater.
The “WFA pack for managing Clustered Data ONTAP” is included in WFA 5.1.1P6 so there is no need to download this pack from the NetAppStorage Automation Store and install it separately onto your WFA server as was required in the past. WFA download
You must have the name of the database user that you created in Unified Manager to support WFA and Unified Manager connections.
This database user must have been assigned the Integration Schema user role.
You must be assigned either the Administrator role or the Architect role in Workflow Automation.
You must have the host address, port number 443, user name, and password for the Workflow Automation setup.
You must have the Application Administrator or Storage Administrator role.
In the left navigation pane, click General > Workflow Automation.
In the Database User area of the Workflow Automation page, select the name, and enter the password for the database user that you created to support Unified Manager and Workflow Automation connections.
In the Workflow Automation Credentials area of the page, enter the host name or IP address (IPv4 or IPv6), and the user name and password for the Workflow Automation setup.
You must use the Unified Manager server port (port 443).
Click Save.
If you use a self-signed certificate, click Yes to authorize the security certificate.
The Workflow Automation page displays.
Click Yes to reload the web UI, and add the Workflow Automation features.
Related information
