Install and maintain
Replace a Cisco Nexus 9336C-FX2 storage switch
Contributors netapp-jolieg
You must be aware of certain configuration information, port connections and cabling requirements when you replace Cisco Nexus 9336C-FX2 storage switches.
What you'll need
You must verify that the following conditions exist before installing the NX-OS software and RCFs on a Cisco Nexus 9336C-FX2 storage switch:
  • Your system can support Cisco Nexus 9336C-FX2 storage switches.
  • You must have consulted the switch compatibility table on the Cisco Ethernet Switch page for the supported ONTAP, NX-OS, and RCF versions.
  • You must have referred to the appropriate software and upgrade guides available on the Cisco web site. Cisco Nexus 3000 Series Switches
  • You must have downloaded the applicable RCFs.
  • The existing network configuration must have the following characteristics:
    • The Cisco Ethernet Switches page has the latest RCF and NX-OS versions on your switches.
    • Management connectivity must exist on both switches.
  • The replacement Cisco Nexus 9336C-FX2 switch must have the following characteristics:
    • Management network connectivity must be functional.
    • Console access to the replacement switch must be in place.
    • The appropriate RCF and NX-OS operating system image must be loaded onto the switch.
    • Initial confiugration of the switch must be complete.
About this task
This procedure replaces the second Nexus 9336C-FX2 storage switch S2 with the new 9336C-FX switch NS2. The two nodes are node1 and node2.
Steps to complete:
  • Confirm the switch to be replaced is S2.
  • Disconnect the cables from switch S2.
  • Reconnect the cables to switch NS2.
  • Verify all device configurations on switch NS2.
    Note There can be dependencies between command syntax in the RCF and NX-OS versions.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all - message MAINT=xh
    x is the duration of the maintenance window in hours.
  2. Check on the health status of the storage node ports to make sure that there is connection to storage switch S1:
    storage port show -port-type ENET
    Show example
    storage::*> storage port show -port-type ENET
                                      Speed                     VLAN
    Node           Port Type  Mode    (Gb/s) State    Status      ID
    node1
                   e3a  ENET  storage 100    enabled  online      30
                   e3b  ENET  storage   0    enabled  offline     30
                   e7a  ENET  storage   0    enabled  offline     30
                   e7b  ENET  storage   0    enabled  offline     30
    node2
    storage::*>
  3. Verify that storage switch S1 is available:
    network device-discovery show
    Show example
    storage::*> network device-discovery show
    Node/      Local Discovered
    Protocol   Port	 Device (LLDP: ChassisID)  Interface  Platform
    node1/cdp
               e3a   S1                        Ethernet1/1 NX9336C
               e4a   node2                     e4a         AFF-A700
               e4e   node2                     e4e         AFF-A700
    node1/lldp
               e3a   S1                        Ethernet1/1 -
               e4a   node2                     e4a         -
               e4e   node2                     e4e         -
    node2/cdp
               e3a   S1                        Ethernet1/2 NX9336C
               e4a   node1                     e4a         AFF-A700
               e4e   node1                     e4e         AFF-A700
    node2/lldp
               e3a   S1                        Ethernet1/2 -
               e4a   node1                     e4a         -
               e4e   node1                     e4e         -
    storage::*>
  4. Run the show lldp neighbors command on the working switch to confirm that you can see both nodes and all shelves:
    show lldp neighbors
    Show example
    S1# show lldp neighbors
    Capability codes:
       (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
       (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
    Device ID        Local Intf   Hold-time    Capability    Port ID
    node1            Eth1/1       121          S             e3a
    node2            Eth1/2       121          S             e3a
    SHFGD2008000011  Eth1/5       121          S             e0a
    SHFGD2008000011  Eth1/6       120          S             e0a
    SHFGD2008000022  Eth1/7       120          S             e0a
    SHFGD2008000022  Eth1/8       120          S             e0a
  5. Verify the shelf ports in the storage system:
    storage shelf port show -fields remote-device,remote-port
    Show example
    storage::*> storage shelf port show -fields remote-device,remote-port
    shelf   id  remote-port   remote-device
    3.20    0   Ethernet1/5   S1
    3.20    1   -             -
    3.20    2   Ethernet1/6   S1
    3.20    3   -             -
    3.30    0   Ethernet1/7   S1
    3.20    1   -             -
    3.30    2   Ethernet1/8   S1
    3.20    3   -             -
    storage::*>
  6. Remove all cables attached to storage switch S2.
  7. Reconnect all cables to the replacement switch NS2.
  8. Recheck the health status of the storage node ports:
    Show example
                                        Speed                     VLAN
    node1
    node2
    storage::*>
  9. Verify that both switches are available:
    Show example
    node1/cdp
              e7b   NS2                       Ethernet1/1 NX9336C
    node1/lldp
              e4a  node2                      e4a         -
              e4e  node2                      e4e         -
              e7b  NS2                        Ethernet1/1 -
    node2/cdp
              e7b  NS2                        Ethernet1/2 NX9336C
    node2/lldp
              e4a  node1                      e4a         -
              e4e  node1                      e4e         -
              e7b  NS2                        Ethernet1/2 -
    storage::*>
  10. Verify the shelf ports in the storage system:
    Show example
    3.20    1     Ethernet1/5     NS2
    3.20    3     Ethernet1/6     NS2
    3.20    1     Ethernet1/7     NS2
    3.20    3     Ethernet1/8     NS2
    storage::*>
  11. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
