Install and maintain
Migrate to a two-node switched cluster in FAS22xx systems with a single cluster-network connection
Contributors netapp-yvonneo netapp-jolieg
If you have FAS22xx systems in an existing two-node switchless cluster in which each controller module has a single, back-to-back 10 GbE connection for cluster connectivity, you can use the switchless cluster networking option and replace the direct back-to-back connectivity with switch connections.
Review requirements
Before you begin
Make sure you have the following:
  • Two cluster connections for migrating from a switchless configuration to a switched configuration.
  • The cluster is healthy and consists of two nodes connected with back-to-back connectivity.
  • The nodes are running ONTAP 8.2 or later.
  • The switchless cluster feature cannot be used with more than two nodes.
  • All cluster ports are in the up state.
Migrate the switches
This procedure is a nondisruptive procedure that removes the direct cluster connectivity in a switchless environment and replaces each connection to the switch with a connection to the partner node.
Step 1: Prepare for migration
  1. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  2. Check the cluster status of the nodes at the system console of either node:
    cluster show
    Show example
    The following example displays information about the health and eligibility of the nodes in the cluster:
    cluster::*> cluster show
    Node                 Health  Eligibility   Epsilon
    node1                true    true          false
    node2                true    true          false
    2 entries were displayed.
  3. Check the status of the HA pair at the system console of either node: storage failover show
    Show example
    The following example shows the status of node1 and node2:
    Node           Partner        Possible State Description
    node1          node2          true      Connected to node2
    node2          node1          true      Connected to node1
  4. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    x is the duration of the maintenance window in hours.
    Note The message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
    Show example
    The following command suppresses automatic case creation for two hours:
    cluster::*> system node autosupport invoke -node * -type all -message MAINT=2h
  5. Verify that the current state of the switchless cluster is true, and then disable the switchless cluster mode:
    network options switchless-cluster modify -enabled false
  6. Take over the target node:
    storage failover takeover -ofnode target_node_name
    It does not matter which node is the target node. When it is taken over, the target node automatically reboots and displays the Waiting for giveback…​ message.
    The active node is now serving data for the partner (target) node that was taken over.
  7. Wait for two minutes after takeover of the impaired node to confirm that the takeover was completed successfully.
  8. With the target node showing the Waiting for giveback…​ message, shut it down.
    The method you use to shut down the node depends on whether you use remote management through the node Service Processor (SP).
    If SP Then…​
    Is configured
    Log in to the impaired node SP, and then power off the system: system power off
    Is not configured
    At the impaired node prompt, press Ctrl-C, and then respond y to halt the node.
Step 2: Configure cables and ports
  1. On each controller module, disconnect the cable that connects the 10 GbE cluster port to the switchless cluster.
  2. Connect the 10 GbE cluster port to the switch on both controller modules.
  3. Verify that the 10 GbE cluster ports connected on the switch are configured to be part of the same VLAN.
    If you plan to connect the cluster ports on each controller module to different switches, then you must verify that the ports on which the cluster ports are connected on each switch are configured for the same VLAN and that trunking is properly configured on both switches.
  4. Give back storage to the target node:
    storage failover giveback -ofnode node2
  5. Monitor the progress of the giveback operation:
    storage failover show-giveback
  6. After the giveback operation is complete, confirm that the HA pair is healthy and takeover is possible:
    Show example
    The output should be similar to the following:
  7. Verify that the cluster port LIFs are operating correctly:
    network interface show -role cluster
    Show example
    The following example shows that the LIFs are up on node1 and node2 and that the "Is Home" column results are true:
    cluster::*> network interface show -role cluster
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    node1
                clus1        up/up    192.168.177.121/24  node1        e1a     true
    node2
                clus1        up/up    192.168.177.123/24  node2        e1a     true
  8. Check the cluster status of the nodes at the system console of either node:
    cluster show
    Show example
  9. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source           Destination      Packet
Node   Date                       LIF              LIF              Loss
node1
       3/5/2022 19:21:18 -06:00   node1_clus2      node2-clus1      none
       3/5/2022 19:21:20 -06:00   node1_clus2      node2_clus2      none
node2
       3/5/2022 19:21:18 -06:00   node2_clus2      node1_clus1      none
       3/5/2022 19:21:20 -06:00   node2_clus2      node1_clus2      none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is node2
Getting addresses from network interface table...
Cluster node1_clus1 169.254.209.69 node1 e0a
Cluster node1_clus2 169.254.49.125 node1 e0b
Cluster node2_clus1 169.254.47.194 node2 e0a
Cluster node2_clus2 169.254.19.183 node2 e0b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
Local 169.254.47.194 to Remote 169.254.209.69
Local 169.254.47.194 to Remote 169.254.49.125
Local 169.254.19.183 to Remote 169.254.209.69
Local 169.254.19.183 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
Step 3: Complete the procedure
  1. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message:
    Show example
    cluster::*> system node autosupport invoke -node * -type all -message MAINT=END
  2. Change the privilege level back to admin:
    set -privilege admin
