Name mapping with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to specify name mapping entries to map users from different platforms.
Name mapping conversion rules
An ONTAP system keeps a set of conversion rules for each SVM. Each rule consists of two pieces: a pattern and a replacement. Conversions start at the beginning of the appropriate list and perform a substitution based on the first matching rule. The pattern is a UNIX-style regular expression. The replacement is a string containing escape sequences representing subexpressions from the pattern, as in the UNIX sed program.
Name Mapping window
You can use the Name Mapping window to specify the name mapping entries to map users from different platforms.
Name Mappings
You can create and use name mappings to map your UNIX users to Windows users, Windows users to UNIX users, or Kerberos users to UNIX users.
Command buttons
Add
Opens the Add Name Mapping Entry dialog box, which enables you to create a name mapping on storage virtual machines (SVMs).
Edit
Opens the Edit Name Mapping Entry dialog box, which enables you to edit a name mapping on SVMs.
Delete
Opens the Delete Name Mapping Entries dialog box, which enables you to delete a name mapping entry.
Swap
Opens the Swap Name Mapping Entries dialog box, which enables you to interchange positions of the two selected name mapping entries.
Refresh
Updates the information in the window.
Name mappings list
Position
Specifies the name mapping's position in the priority list. Name mappings are applied in the order in which they occur in the priority list.
Pattern
Specifies the user name pattern that must be matched.
Replacement
Specifies the replacement pattern for the user name.
Direction
Specifies the direction of the name mapping. Possible values are krb_unix for a Kerberos-to-UNIX name mapping, win_unix for a Windows-to-UNIX name mapping, and unix_win for a UNIX-to-Windows name mapping.
Command buttons
Add
Opens the Add Group Mapping Entry dialog box, which enables you to create a group mapping on SVMs.
Edit
Opens the Edit Group Mapping Entry dialog box, which enables you to edit the group mapping on SVMs.
Delete
Opens the Delete Group Mapping Entries dialog box, which enables you to delete a group mapping entry.
Swap
Opens the Swap Group Mapping Entries dialog box, which enables you to interchange positions of the two selected group mapping entries.
Refresh
Group mappings list
Position
Specifies the group mapping's position in the priority list. Group mappings are applied in the order in which they occur in the priority list.
Pattern
Replacement
Specifies the replacement pattern for the user names.
Direction
Specifies the direction of the group mapping. Possible values are
krb_unixfor a Kerberos-to-UNIX group mapping,win_unixfor a Windows-to-UNIX group mapping, andunix_winfor a UNIX-to-Windows group mapping.
Related information
