System Manager Classic
Manage aggregates with System Manager - ONTAP 9.7 and earlier
Contributors netapp-barbe netapp-mwallis
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create aggregates to support the differing security, backup, performance, and data sharing requirements of your users.
Aggregates window
You can use the Aggregates window to create, display, and manage information about aggregates.
Command buttons
  • Create
    Opens the Create Aggregate dialog box, which enables you to create an aggregate.
  • Edit
    Opens the Edit Aggregate dialog box, which enables you to change the name of an aggregate or the level of RAID protection that you want to provide for the aggregate.
  • Delete
    Deletes the selected aggregate.
    Note
    This button is disabled for the root aggregate.
  • More Actions
    Provides the following options:
  • Change status to
    Changes the status of the selected aggregate to one of the following statuses:
    • Online
      Read and write access to the volumes that are contained in this aggregate is allowed.
    • Offline
      Read and write access is not allowed.
    • Restrict
      Some operations—​such as parity reconstruction—​are allowed, but data access is not allowed.
  • Add Capacity
    Enables you to add capacity (HDDs or SSDs) to existing aggregates.
  • Add Cache
    Enables you to add cache disks (SSDs) to existing HDD aggregates or Flash Pool aggregates.
    This button is not available for a cluster containing nodes with All Flash Optimized personality.
  • Mirror
    Enables you to mirror the aggregates.
  • Volume Move
    Enables you to move a FlexVol volume.
  • Attach Cloud Tier
    Enables you to attach a cloud tier to the aggregate.
  • Refresh
    Updates the information in the window.
Aggregate list
Displays the name and the space usage information for each aggregate.
  • Status
    Displays the status of the aggregate.
  • Name
    Displays the name of the aggregate.
  • Node
    Displays the name of the node to which the disks of the aggregate are assigned.
    This field is available only at the cluster level.
  • Type
    Displays the type of the aggregate.
    This field is not displayed for a cluster containing nodes with All Flash Optimized personality.
  • Used (%)
    Displays the percentage of space that is used in the aggregate.
  • Available Space
    Displays the available space in the aggregate.
  • Used Space
    Displays the amount of space that is used for data in the aggregate.
  • Total Space
    Displays the total space of the aggregate.
  • FabricPool
    Displays whether the selected aggregate is attached to a cloud tier.
  • Cloud Tier
    If the selected aggregate is attached to a cloud tier, it displays the name of the cloud tier.
  • Volume Count
    Displays the number of volumes that are associated with the aggregate.
  • Disk Count
    Displays the number of disks that are used to create the aggregate.
  • Flash Pool
    Displays the total cache size of the Flash Pool aggregate. A value of NA indicates that the aggregate is not a Flash Pool aggregate.
  • Mirrored
    Displays whether the aggregate is mirrored.
  • SnapLock Type
    Displays the SnapLock type of the aggregate.
Details area
Select an aggregate to view information about the selected aggregate. You can click Show More Details to view detailed information about the selected aggregate.
  • Overview tab
    Displays detailed information about the selected aggregate, and displays a pictorial representation of the space allocation of the aggregate, the space savings of the aggregate, and the performance of the aggregate in IOPS and total data transfers.
  • Disk Information tab
    Displays disk layout information such as the name of the disk, disk type, physical size, usable size, disk position, disk status, plex name, plex status, RAID group, RAID type, and storage pool (if any) for the selected aggregate. The disk port that is associated with the disk primary path and the disk name with the disk secondary path for a multipath configuration are also displayed.
  • Volumes tab
    Displays details about the total number of volumes on the aggregate, total aggregate space, and the space committed to the aggregate.
  • Performance tab
    Displays graphs that show the performance metrics of the aggregates, including throughput and IOPS. Performance metrics data for read, write, and total transfers is displayed for throughput and IOPS, and the data for SSDs and HDDs is recorded separately.
    Changing the client time zone or the cluster time zone impacts the performance metrics graphs. You should refresh your browser to view the updated graphs.
Related information
