Deleting FlexCache volumes
Beginning with System Manager 9.6, you can delete a FlexCache volume when you no longer require it.
Before you begin
The junction path of the FlexCache volume must be unmounted.
The FlexCache volume must be offline.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexCache volume that you want to delete, and then click Delete.
Select the confirmation check box, and then click OK.
Related information
