The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Manage FC/FCoE and NVMe adapters with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage FC/FCoE and NVMe adapters.
Edit the FC/FCoE and NVMe adapter speed settings
You can modify the FC/FCoE and NVMe adapter speed settings by using the Edit FC/FCoE and NVMe Adapter Settings dialog box in System Manager.
Steps
Click Network > FC/FCoE and NVMe Adapters.
Select the adapter that you want to edit, and then click Edit.
In the Edit FC/FCoE and NVMe adapter settings dialog box, set the adapter speed to Manual or Automatic, and then click Save.
Related information
