Applications window in System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to display a list of the applications in a storage virtual machine (SVM). The list includes detailed information about each application.
Tabs
Depending on the configuration of the cluster, System Manager displays information about applications using one of the following methods:
No tabs
Detailed information about the application, including the name, the type, storage usage, performance, and related information.
Two tabs
The display provides two tabs of information about the application.
Enhanced
Basic
Basic information about the application.
List of applications
Applications for the selected SVM are displayed on the Enhanced tab in a list in the following ways:
For System Manager 9.5 and earlier, up to a maximum of 32 applications are displayed in the list.
For System Manager 9.6, the first 25 applications are displayed in the list. As you scroll to the bottom of the list, another 25 applications are added to the list. When you continue to scroll, you can continue to add 25 applications at a time to expand the list up to a maximum of 1000 applications.
List columns
The information about each application is listed on the Enhanced tab in the following columns.
Expand/collapse arrow
Contains an arrow that you can click to expand the information to a show a detailed view or to collapse the information back to the summary view.
Name
The name of the application.
Type
The application type.
Component
The component of the application.
ONTAP Service Level
The level of ONTAP service for the application.
Usage
A graphical bar that shows the percentage of usage.
Used
The amount of storage space used by the application.
Available
The amount of storage space still available for the application.
Size
The size of the application.
IOPs
The number of input and output operations per second (IOPs) for the application.
Latency
The amount of latency for the application.
Entry fields
The following fields can be used to modify the display of information:
SVM
Enables you to display a drop-down list of SVMs from which you can select the SVM that contains the applications you want to display.
Search field
Enables you to type all or part of an application name to initiate a search based on the criteria you type. Only the applications with names that match the criteria are then displayed in the list.
Sort by field
Enables you to sort the list of applications based on name, size, or type.
Action icons
The following icons on the Enhanced tab can be used to initiate actions:
Add icon
Enables you to add an application to the selected SVM.
Filter icon
Enables you to specify the type of application you want to display in your search results.
Display icon
Enables you to switch between a list view and a card view of the application information.
