The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Edit LUNs with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use the LUN properties dialog box in ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the name, description, size, space reservation setting, or the mapped initiator hosts of a LUN.
About this task
When you resize a LUN, you have to perform the steps on the host side that are recommended for the host type and the application that is using the LUN.
Steps
Click Storage > LUNs.
In the LUN Management tab, select the LUN that you want to edit from the list of LUNs, and click Edit.
Make the required changes.
Click Save and Close.
Related information
